It is currently Sat Jan 31, 2015 1:27 am
 Post subject: maximumcd stealth file
PostPosted: Fri Dec 10, 2004 1:55 pm
I think I tracked down this file "systemscandata.txt" to the MaximumPC cd and also PC Gamer cd.
It gets installed to the c drive root directory when the cd is run.
Are there any other stealth files that get installed from the cd and can I safely delete it?
PostPosted: Fri Dec 10, 2004 4:57 pm
the "games" screen scans your system to tell you whether or not your system meets the game's minimum requirements. As far as I know, that's the only interaction your PC has with the disc.
PostPosted: Sat Dec 11, 2004 4:46 pm
Thanks for the quick response.
Guess I'll just keep an eye on that file and doublecheck some more.
