It is currently Mon May 04, 2015 5:13 am
 Post subject: Update Your Setup Files doesn't seem to work
PostPosted: Thu Oct 28, 2004 7:35 pm
I'm having problems updating my Windows XP CD. When I try to update my Setup files, the command c:\xpsp2\i386\update\update /s c:\xpsetupcd returns a dialog box listing the available switches, none of which is /s. The only one listed that seems to apply is /integrate: When I try that one I get an error message:
Failed to copy some or all of the file necessay for integrated install
Please check that:
a) No network or copy errors occured during the integration process
b) The formate of the destination directiory is correct
The files to be integrated must reside in an 1386 and/or ia64 or
nec98 directory
(i.e. for an 1386 share, if you typed "update /s c:\cdshare, the
files must be in the c:\cdshare\i386 directory
Everything seems to check out fine, so I am at a total loss as to what I may be doing wrong. Anybody have any suggestions? Thank you.
PostPosted: Thu Oct 28, 2004 8:03 pm
You tried just using C:\xpsp2\ ? I'm pretty sure thats all I had to use.
PostPosted: Thu Oct 28, 2004 10:59 pm
Maximum PC Editor
Maximum PC Editor
I think its
/s:c:/xpsetupcd
at least that's what the text said in the magazine last time I looked. ;)
///Will
PostPosted: Fri Oct 29, 2004 5:41 am
team psycho or sumthin
when i did it i used:
C:\sp2\sp2.exe -x (extract) and
C:\sp2\i386\update\update.exe -s:C:\XP (to slipstream)
http://members.cox.net/drainbread/sp2slipstream.html
PostPosted: Fri Oct 29, 2004 8:00 am
Notched on both sides
Nice Page Drain!
Great job on the step-by-step part - we outta sticky that in Windows Parlor :)
Tuathal
PostPosted: Fri Oct 29, 2004 8:48 am
Ok thanks to all, I found the solution to the problem, I was leaving a space between the /integrate: and the c:\xpsetupcd, there should be no space, all continuous. So the correct syntax should be:
c:\xpsp2\i386\update\update /s:c:\xpsetupcd or:
c:\xpsp2\i386\update\update /integrate:c:\xpsetupcd
I've tried both & they both seem to work
(Feel free to modify it if your data is stored somewhere other than c:\xpsp2 and/or c:\xpsetupcd).
PostPosted: Sat Oct 30, 2004 2:01 am
tuathal wrote:
Nice Page Drain!
Tuathal
oh god no....not that cheep POS...on the plus side it is my first attempt at some sort of webpage
PostPosted: Sat Oct 30, 2004 5:28 am
I agree, nice page drain. That deserves to be in some kind of faq.
PostPosted: Tue Nov 02, 2004 2:13 am
Smithfield*
Smithfield*
nice work!
