It is currently Thu Jan 29, 2015 6:51 am
 Post subject: Update Your Windows XP CD article - New Windows too big
PostPosted: Sat Oct 23, 2004 4:56 pm
Hi there,
I was working through the steps in the article, and everything was going great. However, when I went to burn the new CD, it wouldn't fit on one CD. Any suggestions on how to fix this?
Thanks.
PostPosted: Sun Oct 24, 2004 11:18 pm
Maximum PC Editor
Maximum PC Editor
It worked using an 80 minute CD. I don't think we had any of the old 72 minute jobbers around.
It should also work on a DVD, I think. I didn't test that though.
PostPosted: Mon Oct 25, 2004 2:43 am
Well, my total files came out to be around 875MB, too much for my CD. I thought about trying it out on a DVD, but haven't yet. I wondered if maybe it's because I need so many updates added. My Window XP CD is one of the originals without SP1. Could the difference in versions account for the increased size? Thanks for you help.
PostPosted: Tue Oct 26, 2004 5:46 pm
Notched on both sides
That happens when SP1 and SP2 don't get properly integrated... You have 3 copies (and 3 versions) of some of the files floating on the CD...
See the Following Thread in the Windows Parlor Forum...
Oh It could also be your burning software :)
Cheers,
Tuathal
True Fact: Hippos are so fascinating to some people that a real life version of Hungry Hungry Hippo was created called "Extreme Hungry, Hungry Hippo"
 Post subject: Re: Update Your Windows XP CD article - New Windows too big
PostPosted: Tue Oct 26, 2004 6:00 pm
thefoolisme wrote:
Hi there,
Thanks.
You must be doing something wrong.
Make sure you slipstream SP2, that will get all updates up to that point in the disc. You won't need to manually add them on top of that.
PostPosted: Fri Oct 29, 2004 1:20 pm
Look in the Support directory of the CD. Likely you'll have two directories. One is Tools and I can't remember what the other one was. I just kept Tools and removed the other directory altogether since I didn't really need anything from it. Between the OEM and Retail versions, there is some differences in what is in the Support directories. Remove what's taking up the most room out of the Support directory and you'll be able to bring the size back down to roughly 650MB. :D
PostPosted: Sat Oct 30, 2004 6:13 pm
Smithfield*
Smithfield*
Brings up an interesting point though, about Bootable DVD's. I;ve made plenty of bootable CD's, is making a bootable DVD pretty much the same?
PostPosted: Sat Oct 30, 2004 6:35 pm
team psycho or sumthin
i dont have a DVD burner so i cant say for sure...BUT i think if you set the sector count(using roxio not sure about nero)to 4 just like you do a CD it should work
