It is currently Tue Apr 28, 2015 12:22 pm
 Post subject: Noticing inconsistancies in the articles lately
PostPosted: Fri Oct 22, 2004 5:11 pm
I noticed in the October issues Longhorn article a few errors. One example is the editor goes on to say that Longhorn has a new file system called WinFS, then goes on later in the article and contradicts himself saying it just runs on top of a modified NTFS file system. Try to be a little more careful in your articles in regards to accuracy in the future.
PostPosted: Fri Oct 22, 2004 6:54 pm
longhorn was going to use WinFS but it nolonger will
see here:
http://msdn.microsoft.com/data/winfs/
PostPosted: Fri Oct 22, 2004 9:25 pm
I am aware of this, however, that info has been public knowledge for some time now that it will not be a completely new file system. Yes I can understand the part about it not being included was probably announced after this article was written. However, my argument is based on the fact that the author stated that it was a completely new file system, then later in the article went on to say it was just something that ran on top of NTFS.
PostPosted: Sun Oct 24, 2004 11:16 pm
Maximum PC Editor
Maximum PC Editor
You're arguing semantics. I usually don't bother arguing back on this kind of little nit-picky stuff, but this time I will, since we're both kind of right and I didn't have the time to fully explain it in the story..
From what I've seen, WinFS is kind of a new thing, at least in the Windows world. In the alphas it seems to create a filesystem inside a bigass file that has to sit on an NTFS partition. At least, that's how the PDC (and I think the WinHEC) builds worked.
It's unclear to me whether that was just how it worked in the tech preview or if it will continue to work like that when (and if) it ever ships.
///Will
PostPosted: Sun Nov 14, 2004 8:22 am
interesting, so its still basicly just NTFS with a nifty feature? sorta like when fat went 32? or is it more than that? like fat to NTFS?
PostPosted: Sun Nov 14, 2004 2:53 pm
An easy way to think of it (that is, a layman's explanation) is that WinFS adds a db that sits on top of NTFS. It is a great idea ... I'm quite disappointed that it was removed from Longhorn.
Having said that, an open-source version is bound to be released ... probably before MS does, now ... so I'm happy either way.
To address the original poster's concern ... WinFS is a new filesystem AND it is based on NTFS. The features that it adds are revolutionary and extensive, so it is correct to call it new ... but it is built on the core of NTFS, so it is also correct to say that it is based on NTFS. It is, as Will said, simply a question of semantics.
A analogy to cars is often useful, so I'll throw one in to clarify my point. The Toyota Matrix is a new car. The high-end Matrix uses the same engine as the Toyota Celica GT-S. So it is a new car that happens to have the same engine as a previously existing model.
PostPosted: Mon Nov 15, 2004 12:39 am
Maximum PC Editor
Maximum PC Editor
New Shimmer is a floor wax!
No, new Shimmer is a dessert topping!
PostPosted: Mon Nov 15, 2004 1:04 pm
MMMMMMMM... New Shimmer :wink:
