It is currently Sun May 03, 2015 4:52 am
 Post subject: Your RAID tests, try RAID 1 for a change!
PostPosted: Tue Oct 19, 2004 7:29 pm
Why on earth are you guys only using RAID 0 and complaining that RAID performance is no different or worse for games? Why don't you give RAID 1 a try since read performance is improved. And logically games will benefit from the increase in read performance (load times).
 Post subject: Re: Your RAID tests, try RAID 1 for a change!
PostPosted: Wed Oct 20, 2004 9:22 am
Because everybody seems to use RAID 0 (for whatever reason) to "benefit" their machine's gaming performance.
I'm not entirely sure that's true. RAID 1 is about mirroring, not performance. Even if it is true, nobody cares that much about load times.
PostPosted: Wed Oct 20, 2004 1:05 pm
Celeron
Celeron
RAID 1 is essentially the same performance as one drive.
That said, load times can be improved dramatically by increasing the amount of RAM in your system.
PostPosted: Wed Oct 20, 2004 3:13 pm
Raid 1 provides read times that are improved over a single drive, but they are not faster than RAID 0 times, at least as far as benchmarks are concerned.
Therefore, if we're doing tests to see the speed benefits of RAID, it makes sense to use RAID 0 because:
1. It's the fastest, most common form of RAID for home users
2. It's much faster in benchmarks than RAID 1
PostPosted: Wed Oct 20, 2004 4:03 pm
I miss my [Ch]ams!
I miss my [Ch]ams!
Josh,
Okay, so it's been "proven" that for typical desktop use, RAID has little if any advantage over a single drive.
What about for servers? Can a SCSI RAID handle, e.g., more I/O's per second than a single drive? Thx!
-[Ch]ams
PostPosted: Thu Oct 21, 2004 1:06 am
I say get 4 WD 74GB Raptors in a RAID 0+1 config and give that a go on the new Intel 925 chipset board, which has the new ICH6 southbridge that has support 4 SATA ports plus RAID 0+1. I would also try testing this config using a highend 3ware SATA RAID controller consider that with the ram it has onboard you should see some increase in performance for games. Don't give up!
PostPosted: Tue Oct 26, 2004 7:43 am
M-Powered
M-Powered
Netcell's RAID-XL is far superior to your puny RAID-1 or 0 or 5 for that matter... :P
PostPosted: Tue Oct 26, 2004 7:46 am
M-Powered
M-Powered
This rapes any 3ware card.
PostPosted: Tue Oct 26, 2004 9:14 am
Out of curiousity, what drives are you using on yours? I was using WD Special Editions and kept having problems. When it worked, it was AWESOME.
PostPosted: Tue Oct 26, 2004 9:29 am
M-Powered
M-Powered
I use Hitachi's S-ATA 7k250 Deskstars. Haven't had any issues yet.
PostPosted: Tue Oct 26, 2004 9:34 am
Cool, I'll check 'em out. I'll have to get the PATA equivilent though, as I have the 'older' XL-3000.
