It is currently Fri Apr 17, 2015 10:12 pm
 Post subject: October 2004 Issue: How to Update Your WinXP CD
PostPosted: Sun Sep 26, 2004 1:43 pm
Does anyone know if the same steps for including SATA and RAID drivers can be used for other drivers?
PostPosted: Thu Sep 30, 2004 3:57 pm
Maximum PC Editor
Maximum PC Editor
It depends on the device. There's a pretty good guide on how to do additional drivers at http://greenmachine.msfnhosting.com/
I would think that network drivers and stuff like that would be pretty easy. However, drivers that also come with a bunch of utilties (Creative's) won't be able to.
///Will
PostPosted: Tue Oct 12, 2004 6:00 am
hello, first post here, new reader and I love the mag, BUT>>>>
I'm trying to follow the instructions to Update my windows xp install cd to include service pack 2. In step 1 it says to look under the windows xp section for service pack 2. I don't see it! I see one for IT developers and advanced users, and tried them both but going to step 2 it doesn't work!! I looked all over microsoft.com and all I can find is that if I want sp2 I have to go to windowsupdate.com which is stupid because I dont' want to update I want to download it so I can follow your friggin guide. please help! thank you!
PostPosted: Tue Oct 12, 2004 6:10 am
NEVER MIND, GOT IT. It was the IT one, I neglected to navigate to the update folder.... duhhhhhhhh thanks anyway
