It is currently Fri May 24, 2013 8:13 am
 Post subject: Coolermaster l3
PostPosted: Sat Apr 29, 2006 11:37 am
The review done on the l3 was bad and inacuate because all the test were done with the fan at its lowest speed. If your going to do a review atleast do it right before you come up saying that the cooler is crap. To make the fan go at full speed and you dont have a pwm board just put a wire between the fourth and second pin and it will spin at full speed.
PostPosted: Tue May 02, 2006 2:12 pm
The fact that the PWM was not activated is a good thing. This is marketed as a "silent" cooler, so it's standard mode of operation is with the fan spinning slowly. We didn't say it was crap, we just said it's not any better than the stock cooler from Intel, and as such is underwhelming.
PostPosted: Sat May 06, 2006 4:43 pm
Yes, but your not using the cooler to its fullest it could for sure cool a few more c but it would be a bit louder. Im just saying if your gonna do a review do it right you should have tested the fan at low speed and at high speed.
