It is currently Fri Mar 06, 2015 6:12 am
 Post subject: Unheard of Util, That relates also to one of your Articles!
PostPosted: Tue Sep 21, 2004 8:09 am
in the October edition there should be one added Utility, called nLite
Click here for details http://nuhi.msfn.org/guide/ This automizes the slipstreaming (Though arguably it's already automized) But it also does much more! You can intergrate your own drivers for installation and customize unattended setups through a GUI. You can also -strip- IE and/or it's core from the Windows XP Install, and remove many other features. The main page is http://nuhi.msfn.org
PostPosted: Tue Sep 21, 2004 6:47 pm
Thanks for the heads up. I'll check it out. :D
