It is currently Sun Jan 25, 2015 5:03 am
 Post subject: Check Compatibility and Drivers
PostPosted: Thu Feb 06, 2014 11:52 am
For SSD. I have Asus G75VW portable. How do I get into my setting Bios. When I startup, the system takes me directly into into Windows 8.1
This is based on article "Fine-Tune Your SSD".
Bob
 Post subject: Re: Check Compatibility and Drivers
PostPosted: Thu Feb 06, 2014 12:08 pm
Keep pressing Esc while the computer is booting. Or pull up the charms and go to Settings > Change PC Settings > Update and Recovery > Recovery and click on "Restart Now" where it says Advanced Startup. When you get to advanced startup, go to Troubleshoot > Advanced options > UEFI Firmware Settings
PostPosted: Thu Feb 06, 2014 12:14 pm
Thanks for the time and help.
Bob
PostPosted: Mon Jan 19, 2015 9:07 pm
>>Keep pressing Esc while the computer is booting<<
I have since found, Asus Support, the following:
Hold Down F2
While holding down F2 hit the enter key and release. Make sure you're still holding down the F2 when you release enter.
Seems to work good. At least on my G75VW. I have yet to try it on my P8Z77-V Deluxe motherboard.
Bob
