It is currently Sat Apr 25, 2015 3:39 pm
 Post subject: Another Best of the Best request. Update the hard drive pls
PostPosted: Mon May 27, 2013 7:48 am
MAXIMUMPC best hard drive is the Seagate Barracuda 3GB. Well if I'm looking at the correct drive on Newegg its failure rate is unacceptable to be considered best of the best IMHO.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148844
If anyone can recommend another drive in the meantime I'd appreciate it. 2 to 3 tb. I'm on a budget so not interested in the newer 4tb. I need capacity and speed so an SSD won't cut it. The Seagate would have done the job it it wasn't failure proned.
thanks
 Post subject: Re: Another Best of the Best request. Update the hard drive
PostPosted: Mon May 27, 2013 8:46 am
Pick any of them... really. Well any non green drive. If you want something tuned for reliability, pick a WD Black.
Also while I understand user reviews on Newegg can show about a product, keep in mind that people are more inclined to report a bad experience than they are a good one.
