It is currently Mon Apr 27, 2015 10:07 pm
 Post subject: Need review of IHS removal and comparison
PostPosted: Thu Apr 26, 2012 10:14 am
I have read a few posts about removal of the integrated heat spreader. Some can be removed with just a razor blade while others require heat from a torch, etc. I would like to know the differences in temperature, maybe a comparison of processors with and without the IHS. It would make a great article if it hasn't already been done. Thanks in advance.
 Post subject: Re: Need review of IHS removal and comparison
PostPosted: Thu Apr 26, 2012 12:11 pm
Removing the heat spreader is a bad idea for one sole reason: it's almost a surefire way to break the CPU. I also want to say for LGA based sockets, the heatspreader is part of the retention design. If not that, then your heat sinks may not sufficiently press against the CPU die. And the cooling performance varies, but the question is if it's worth risking your $200+ part. If you want better performance out of the IHS, lap it (but again, this doesn't bring much performance benefit anyway)
More info:
http://www.tomshardware.com/reviews/wol ... 777-6.html
http://www.legitreviews.com/article/402/1/
http://www.xtremesystems.org/forums/sho ... REMOVE-IHS!
