It is currently Thu May 23, 2013 10:39 pm
 Post subject: July 2012 issue - Operation Upgrade... gone wrong
PostPosted: Mon Jun 25, 2012 6:47 am
I noticed that on page 28 in the July 2012 issue of MPC that the CyberPower Xtreme 3200 PC was upgraded with new RAM, a videocard, OS and an SSD.
While I don't have a problem with any of the upgrade choices, I couldn't help but notice that the SSD was ziptied to the side of the hard drive cage.
Ziptied.
Really? I mean, holy hell, this is Maximum PC, the magazine that isn't afraid to do things the right way. An SSD mounting tray costs less than $10... you can't tell me that whoever put that upgrade together (Gordon and Nathan?) thought, "Gee, this is an okay way to install an SSD".
Seriously, I buy Maximum PC for a reason... you guys are all about Minimum BS... except this time.
 Post subject: Re: July 2012 issue - Operation Upgrade... gone wrong
PostPosted: Sun Jul 01, 2012 12:10 pm
You don't like zipties? How would you fit the drive then? Machine it out on a CNC out of Billet Titanium?
You work with what they give you, and THAT'S been MPC from the beginning. I water cooled with a 2L bottle of WalMart DI water from the battery isle and an unknown tubing called "Tygon". Zip ties have been geek all along dude. When you get into fancy $15 fittings, you're into some other place. Hipster perhaps?
I love zipties. Welcome to the fold. It's an SSD bro!
PostPosted: Sun Jul 01, 2012 8:27 pm
:roll:
PostPosted: Tue Jul 03, 2012 9:16 am
Maximum PC Editor
Maximum PC Editor
Hi guys,
We zip-tied that SSD because the drive rails for that case were missing. Without the rails we couldn't use an adapter. Hence the zip-tie.
PostPosted: Tue Jul 03, 2012 9:20 am
nedwards wrote:
Hi guys,
The "Location" under your avatar should be "Aboard the Starship Enterprise"
PostPosted: Tue Jul 03, 2012 9:25 am
Maximum PC Editor
Maximum PC Editor
Well, it does say *secret* headquarters.
