It is currently Sat Apr 25, 2015 5:25 pm
 Post subject: All out WHS 2011 highpoint raid question
PostPosted: Mon Dec 12, 2011 5:44 pm
i am building a similar whs as shown in the holiday 2011 magazine.
i have a few questions about the hdd setups
if i have X # of drives connected, does all of them have to match in terms of TB size?
if i have 4 drives connected, what would happen if i add additional drives? will everything have to be wiped and rebuild the raid, or will it automatically set up?
if i have 6 drives connected with 2TB drives, what do i have to do to upgrade each one to 3 TB drives?
thanks
 Post subject: Re: All out WHS 2011 highpoint raid question
PostPosted: Fri Dec 16, 2011 1:46 am
So I have to read MPC's suggestion to try to answer this? MPC is usually 2 months behind, have their flaws, and the forum usually as to debate something that is 4 months old.
Forget everything in that issue. WHS2 is what you want, it still has issues with backups over a set amount of capacity, and you have to deal with it. There's a 2TB limit on backups, so start with that on the server. Make sure all host backups fit on a 2TB drive along with what the WHS runs on. Here we're all SSD's so a 750G drive is an easy %root% drive. After that, you're free to run the HOME server.
No drives have to match, and I think that's good. If you want DVD ISO's to be Drive F:, the do it. If you want MP3's and Video's to be E:, do that too. But if you want all drives to mash up and then sort them out in the OS...that's not what you really want in a server. It's possible though with an ad-on.
Server. Order. You want this. I feel I have an awesome WHS2 iTX case. Compile, simplify. If you have 4 drives and want to add four more...move the data off the others to the horde. Then you have empty drives.
Think bro. If you have 2TB drives with data, they don't just float over to 3TB drives cleanly. They move of course...so keep it simple and just move it all over from the 2 into the 3.
PostPosted: Sun Feb 05, 2012 7:00 am
old topic that you likely have figured out, but I have whs2011 and rocketraid 2320. to migrate a raid array to new size drives, use the high point online capacity expansion utility (oce). remove one disk at a time, replace with the 3tb disk, rebuild the array. repeat until all disks have been replaced, but you will have the same size array. at that point you use the oce tool to expand the array to the full capacity. I did this when moving from 1tb to 2tb drives...it takes a good week to do since you have to rebuild so be patient and I would recommend taking the server offline when doing this.
PostPosted: Fri Feb 17, 2012 10:16 pm
He's building, not converting..and thanks for the fish.
It's an OS on a low end machine. It's no different than any other install/build than a normal PC. It's a WHS, not a server.
