It is currently Tue Mar 03, 2015 9:29 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Disillusioned with mpc, quitting.
PostPosted: Fri Oct 14, 2011 5:28 pm
OOooooo. You have the teensy leetle touchscreen one.
Why not just mount it on your glasses and add a camera?
HUD and night vision in one!
PostPosted: Fri Oct 14, 2011 5:30 pm
Cause Cortana doesn't like that. She's a little bossy, every argument ends up something something release the flood... something...
PostPosted: Fri Oct 14, 2011 5:32 pm
Okay. How about just implanting an equivalent screen in your retina? She wouldn't even notice!
PostPosted: Fri Oct 14, 2011 5:36 pm
she likes to be touched and man handled in my pocket, plus I don't like the idea of a touch screen in my eye... seems.. icky
PostPosted: Fri Oct 14, 2011 5:41 pm
No, that's just the display. The touchscreen and a secondary display go under a flap in your arm. The flap is then closed. You tap your arm, and the screen activates. If the procedure is done right, then you don't see it when it's off, and it will work juuuust fine. :)
PostPosted: Fri Oct 14, 2011 8:30 pm
This thread just got really creepy.
PostPosted: Sat Oct 15, 2011 7:28 am
I try to bring the Japanese humor ITT
PostPosted: Sat Oct 15, 2011 7:31 am
And I bring the Star Wars cyborg references. :)
PostPosted: Sat Oct 15, 2011 7:33 am
Plz.... try to count the amount of references I pulled in my posts... Star wars got nothing on king kong... or so says Denzel Washington.
PostPosted: Sat Oct 15, 2011 7:50 am
I was also referencing a book you probably never read. Of course, also three different Star Trek episodes.
Weapons are so much cooler when they use plasma, don't you think?
As for Denzel Washington,
Quote:
No.
--"The Book of Eli"
PostPosted: Sat Oct 15, 2011 9:39 am
plasma might be cool and have greater shield penetrating power, but their range is lack luster. Give me a spinfusor any day for the week.
PostPosted: Sat Oct 15, 2011 11:10 am
How about a neutrino beam? It could be accelerated faster than light, and the relativistic properties of such a system would give it a nearly unlimited coherency. Also, the neutrino's effect on subspace would cause massive space/time ruptures in the target.
See Voyager: Season 1, the episode where they use a neutrino beam to rupture a black hole's event horizon.
Plasma coherency is mainly affected by atmosphere and gravitational forces. If you go for a thinner but longer bolt, the increased energy required to thin the bolt would also increase the range considerably. And let's not forget the good, old-fashioned A-bomb, which could be teleported into the inside of the opposing vessel, or sent in via the sub-space rift caused by the neutrino beam.
PostPosted: Sat Oct 15, 2011 2:54 pm
A neutrino beam isn't a weapon system. Also they used a Dekyon beam to open the fissure.
If you want some serious power you are talking about the Tricobalt or Isolytic based weapons systems, which are banned by the Federation. Also Multikinetic neutronic mines were used in season 4 of voyager.
PostPosted: Sat Oct 15, 2011 3:07 pm
While it is not a normal weapon, the subspace distortions Neutrino beams cause could be lethal.
And VOY Season 1 Episode 1, Voyager fired two Tricobalt devices at the alien space station. I somehow doubt that they were illegal at that time.
Three proton torps (SW, not ST) would work.
PostPosted: Sat Oct 15, 2011 3:11 pm
yes, that's why it was a fishy story for a dreadnought class ship of storing illegal weapons. Hinting at the possibility that Voyager had an alternative mission that only the Captain knew. Think Omega mission. This was re-lived with season 6, episode 9 as 7 of 9 relayed it as a conspiracy.
PostPosted: Sat Oct 15, 2011 3:14 pm
I'm still waiting for season 2 to get in. I've only watched season 1, and that was a week ago. While I wait, I'm watching TNG Season 1.
PostPosted: Sat Oct 15, 2011 3:22 pm
I've got Voyager, TNG, DS9 and even Enterprise (with archer) on dvd. Re-watched all of the episodes in the past few months, Along with Breaking Bad, How I meet your mother, Two and a half Men, and Modern Family. I really want to see Mad Men, but I've got a few other shows in my Que first.
PostPosted: Sat Oct 15, 2011 7:35 pm
A pair of geeks with time on their hand :D
PostPosted: Sat Oct 15, 2011 8:56 pm
It's what one does when you are unemployed and between jobs...
PostPosted: Sat Oct 15, 2011 9:50 pm
That's not time in your hand, bro.
:roll:
