It is currently Sat May 25, 2013 12:52 pm
 Post subject: Athlon system upgrade question..XP or 64?
PostPosted: Sun Jul 18, 2004 2:00 pm
I currently have an ABIT NF7 rev. 2.0 board with an AthlonXP 2600+ (333FSB). I was almost ready to purchase an AthlonXP 3200+ (400FSB) when I noticed an Athlon64 2800+ CPU that was $3 cheaper. Of course, if I went with the Athlon64, I would have to buy a new mobo. I definitely want to be able to play HL2 when it comes out. So, what do you guys think? XP 3200 or 64 2800 + a motherboard? Has anyone seen how these two CPUs compare head-to-head? Thanks in advance for any feedback.
PostPosted: Sun Jul 18, 2004 2:19 pm
well, the performance from the 3200+ would probably be better, but its basically on a dead socket. if you want the ability to upgrade go with the 64 2800+ but if you want sheer speed for now go with the 3200+.
PostPosted: Sun Jul 18, 2004 2:38 pm
Contributing Writer
Contributing Writer
I would go with neither and wait until the Socket 939 A64's become affordable. However, if I HAD to pick out of those two, I would go the 3200+ XP route.
That recommendation is, again, based on intentions to perform a platform upgrade once 939 reaches an attractive pricepoint. I would even look at the 3000+ to save $40 on the tide-me-over speed boost. Still hard for me to justify the expense on this assumed temporary upgrade.
 Post subject: Re: Athlon system upgrade question..XP or 64?
PostPosted: Sun Jul 18, 2004 2:48 pm
have you tried overclocking your 2600+? you could oc it for now for a free performance boost and get a socket 939 athlonm 64 like the previous post recommends. i would wait for socket 939 to be affordable to upgrade so you have future upgradeability that neither socket 754 or socket a have.
PostPosted: Sun Jul 18, 2004 4:05 pm
Not to mention the possible need for Registered memory, which is pretty pricey and has a notable performance hit vs. using un-registered sticks. You'll have to factor in these costs as well, or choose wisely with this in consideration.
I also agree that 939 is worth waiting for, then just order up the entire base components together. An Abit/Asus AV8/A8V mobo and a 3500+ should be a big jump for you and think you'll be much happier in the long run. This will take some money ($500 sound like a good forecast for both?), so if you are strapped and don't think you can get this down the road, I really don't know what to say.
PostPosted: Sun Jul 18, 2004 7:44 pm
id go with the 64
better performance
PostPosted: Sun Jul 18, 2004 11:02 pm
I believe only the Socket 940's need registered DDR, and since he mentioned an A64 2800 proc. he wouldn't be able to use it with a Socket 940.
Another vote for the Socket 939 setup. It may cost a little more, but to me it's worth it. Not only can you use a 939 A64 and A64-FX proc., but you also don't need the dreaded registered ram. So with a 939 setup it will surely be the best as far as upgradability goes. I plan to do this as my next upgrade in a month or so.
EDIT: You can also try overclocking as athlon11 mentioned. Spending less money for the cooling hardware possibly needed.
PostPosted: Sun Jul 18, 2004 11:08 pm
Your proc and mobo are still decent. Hang on to them for now, then once HL2 actually comes out reconsider what to upgrade with.
PostPosted: Mon Jul 19, 2004 7:45 am
personally, i'd go with the A64. i just would not buy an Athlon XP CPU at this time.
PostPosted: Mon Jul 19, 2004 8:12 am
well, he should only go with the a64 cpu if it is a socket 939 part. both socket 754 and 940 are soon going to be dead as desktop technologies with everything consolidating in the socket 939 formfactor.
PostPosted: Mon Jul 19, 2004 8:26 am
