It is currently Sun Jan 25, 2015 3:50 am
 Post subject: Changing out D875PBZ to ASUS P4C800?
PostPosted: Fri Jul 16, 2004 9:12 am
Aside from the overclockability of the P4C800 over the D875PBZ, what other benefit would I see in changing boards?
David
PostPosted: Fri Jul 16, 2004 9:26 am
Contributing Writer
Contributing Writer
Overclocking
Multiple RAID
Wi-Fi
Benchmarking
Unless planning on doing some heavy overclocking, you're not going to see any "benefit" in swapping. You already have a solid, Canterwood mobo, and the benchmarking in all reality is minimal.
PostPosted: Fri Jul 16, 2004 10:40 am
I wouldn't "upgrade" to just a P4C800, but go the extra distance and opt into the Deluxe. Here's a good read on why it's still a Kickass board:
Tomshardware updated review of 875 boards
I still love the Abit IC7-Max3, but if I had zero interest in overclocking, then the Asus would be my choice hands down.
PostPosted: Fri Jul 16, 2004 11:12 am
Intel mobos are usually pretty good, just not with lots of the goodies that others offer. i would stick with the Intel unless you have a need for a lot of the onboard stuff of the asus
 Post subject: Re: Changing out D875PBZ to ASUS P4C800?
PostPosted: Fri Jul 16, 2004 12:46 pm
David
make sure if that if you do the switch, that the Asus has the -E at the end, as in P4C800-E, else you'll be missing out the CSA gigabit ethernet.
ability to overclock is the only benefit i see.
