It is currently Sun Apr 26, 2015 12:35 pm
 Post subject: PCIe to AGP bridge?
PostPosted: Wed Jul 14, 2004 8:01 pm
Hi all! just a quick question. I was wondering if any of the upcoming PCIe vid cards from Nvidia and ATI will ever come with a bridge like adaptor to use them on current AGP spec mobos. The reason is that if i buy a next gen vid card, i would still like to be able to use it on a PCIe enabled mobo when i upgrade from a AGP mobo. I think i read somewhere a while ago of some device, but then again i could have been misreading hehe. Any info is greatly apprecieated. im gonna try looking for some info on google again see if anything will turn up that i missed. Thx all =)
 Post subject: Re: PCIe to AGP bridge?
PostPosted: Wed Jul 14, 2004 8:06 pm
Such a device wouldn't woork because there is no physical space for the adapter to fit between the card and the slot.
there was a card one time that had an AGP slot and a PCI slot on the card.
PostPosted: Wed Jul 14, 2004 8:19 pm
doh! oh well , looks like im waiting for the PICe bandwagon then =) thx for the quick response.
PostPosted: Wed Jul 14, 2004 9:09 pm
What do you mean there isnt space?
Theres plenty. More than likely you wouldnt be able to screw it in to the original screw hole on the backplate though.
PostPosted: Wed Jul 14, 2004 11:54 pm
I believe that "screwing it in" part is what he meant. Putting an adapter in there will raise it too much to fit right. Just defending the poor guy a bit ;)
...just a bit though.
PostPosted: Wed Jul 14, 2004 11:57 pm
Riks, that's the delima alot of people are facing...To jump on, or not to jump on the express wagon.
Some boards are offering crossover versions that use both, but yet not worth the money due to the performance hit that comes along with being wishy-washy. I say jump when the time is ready.
PostPosted: Thu Jul 15, 2004 8:06 am
My statement was made with the assumption that the guy wasn't going to mod his case.
But I know what that makes me....
PostPosted: Thu Jul 15, 2004 8:12 am
You dont have to mod it
You just cant secure it properly :P
PostPosted: Thu Jul 15, 2004 8:15 am
I'm sorry, but the idea of running and card, let alone a brand spanking new videocard, that is not properly secured is just plain stupid. Not only can you very easily ruin the card, but also the motherboard.
in any case I don't think anyone is making a PCI-Express to AGP bridge as an add-on part so............
PostPosted: Thu Jul 15, 2004 8:44 am
Sarcasm, get it?
PostPosted: Thu Jul 15, 2004 11:54 am
iv looked at a couple next-gen mobos, and some come with both PCIe and AGP, you could invest in one of those if you want...
i would wait though
PostPosted: Thu Jul 15, 2004 2:06 pm
damnit, I need new glasses... :roll:
hullo someguy!
PostPosted: Thu Jul 15, 2004 5:23 pm
thx for all the info all! I think i will stick with my trusty 9800pro for now. Who knows, by the time PCIe is fully in the market, there will be some new GPU's. I was just tempted by the x800pro and 6800 GT. *slaps self on face* gotta hold on out for PCIe...got to hold out for PCIe =)
PostPosted: Thu Jul 15, 2004 5:31 pm
good plan, methinks. a 9800Pro should be good enough for Doom3.
PostPosted: Thu Jul 15, 2004 6:57 pm
AGP will still be around for a little while yet...I wouldnt worry.
PostPosted: Thu Jul 15, 2004 7:13 pm
Ya. Good idea. PCIE is only out for the new Intel 915 and 925 chipsets anyway (or some not so exciting 865 boards). By the time they get the "REAL" 925XE chipset out, AMD should have some as well to pick through. I can only hope at least :p I'd be all over the AMD upgrade path if they were announcing that they'll adopt PCIE soon.
