It is currently Sun Apr 19, 2015 11:19 am
 Post subject: video card upgrade
PostPosted: Tue Jul 13, 2004 1:11 pm
Hey all..
getting ready to upgrade my videocard. I currently have
AMD 3000+ 333fsb
512 megs 2700
15" flat panel... highest res is 1024 x 768
open agp 8x slot
I have the choices narrowed to the geforce 5900xt or an ati 9700pro
I think i am set on the 5900 becuase i have a geforce 4 igp in my system and from what I read, the ati card might cause compatability problems with that. So I am just looking for advice on this before I drop 200 dollars on a new card.
Thanks =)
PostPosted: Tue Jul 13, 2004 1:30 pm
why a 9700 Pro?
the 9800XT is comparable to the 5900 Ultra.
I suggest the 9800Pro or XT.
PostPosted: Tue Jul 13, 2004 1:36 pm
dont want to spend more then 200 dollars
the 9700 pro and the 5900xt are both available for around 180
PostPosted: Tue Jul 13, 2004 1:38 pm
yoohoo! *smooch* you can thank me later
http://www.newegg.com/app/SearchProduct ... 268&DEPA=0
SAPPHIRE ATI RADEON 9800 PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -BULK
- Specifications -
Chipset/Core Speed: ATI RADEON 9800 PRO/380MHz
Memory/Effective Speed: 128MB DDR/680MHz
BUS: AGP 8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 4 Cables, VGA via DVI Adapter, PowerDVD, Driver CD
Max Resolution@32bit Color: 2048X1536@85Hz
Model#: RADEON 9800PRO 128M
Item#: N82E16814102268
Rating: Vote(s): 423 Review(s): 260
Free FedEx Saver Shipping
Stock:Yes Price:$199.00
PostPosted: Tue Jul 13, 2004 2:15 pm
Contributing Writer
Contributing Writer
I would not give much worry to compatibilty problems. Your best bet for the money is the 9800 Pro. You can have a retail MSI 9800 Pro for $194 shipped:
http://tinyurl.com/3ne5j
Not sure what the bundle is, but it says at the bottom that it comes with "10 games."
PostPosted: Tue Jul 13, 2004 4:18 pm
check out www.pricewatch.com and see the prices of the radeon 9800pro. i think you can get the radeon 9800pro now for like around 200bucks. its worth the money
PostPosted: Tue Jul 13, 2004 10:37 pm
I totally concur with everyone else, the Radeon is a great card and well worth the money. :)
 Post subject: Re: video card upgrade
PostPosted: Wed Jul 14, 2004 3:39 am
There are no compatability problems with the nForce chipset and ATI's videocards. That would be suicide for either company.
PostPosted: Wed Jul 14, 2004 5:39 am
Astro lube 2 the MAX!
in goat we trust. Go with the goat's suggestion on the 9800PRO card.
I own a nforce2 based system w/ATI 9500PRO w/o any whatsever problems.
PostPosted: Wed Jul 14, 2004 6:29 am
running nForce1 with ATI 9500 PRO, no problems.
yes, as others have said, for your budget, go with a 9800 PRO, unless the games you plan run better with nVidia cards, then get the 5900.
