It is currently Mon Mar 30, 2015 5:35 am
Post new topic Reply to topic  [ 19 posts ]
 Post subject: Need Help Building A System!
PostPosted: Mon Jul 12, 2004 9:58 am
Hi, I was hoping someone could give me suggestions on building a computer under $1,200 for LAN parties. It would need a decent graphics card (better than a Radeon 9600SE 128mb), ethernet ports, sound card, HD, mobo, etc. I would prefer 64bit cpu, but P4 are just as good for me. Suggestions on system setup would be greatly appreciated.
Thank You!
31337 $n1p3r
 Post subject: Re: Need Help Building A System!
PostPosted: Mon Jul 12, 2004 10:00 am
Thank You!
31337 $n1p3r
Do you need a monitor/speakers/KN/etc?
 Post subject: Oh yeah...
PostPosted: Mon Jul 12, 2004 10:02 am
Thank god no! I have some nice speakers keyboard, mouse, monitor, etc. I can use a new sound card though! Thanks for asking!
31337 $n1p3r
PostPosted: Mon Jul 12, 2004 10:17 am
Here's what I would build for ~$1200 (all prices from newegg):
Antec Aria (SFF case, takes mATX motherboards)
MSI K8TM-ILSR Socket 754 motherboard.
Athlon 64 3000+
1GB (2x512) Corsair Value select PC3200
120GB WD hard drive
NEC ND-2500A 8X DVD-RW
Audigy 2 ZS.
Total: $822
I intentionally left out the videocard, since that's a bit volatile currently. If you're buying it tomorrow, I'd recommend a vanilla GeForce 6800. They cost about $300. If you aren't buying for a month or so, I'd wait until the X800 Pro/6800GT's come down to your price range. Failing those, a 9800 Pro is always a good choice for $200, just don't expect 1600x1200 goodness with DX9 titles.
The Aria *may* not have the juice to power an X800/6800GT, but unless you actually try it, there's no way to know.
PostPosted: Mon Jul 12, 2004 10:21 am
Athlon 64 3000+
120GB WD hard drive
Audigy 2 ZS.
Total: $822
I want a HTPC so bad :P
PostPosted: Mon Jul 12, 2004 10:24 am
You too will ph43r my wooden wonder if and when it's completed.
 Post subject: Thx!
PostPosted: Mon Jul 12, 2004 10:34 am
Thx! I'll look into that, I have an extra Radeon that I could use for a few months. Any more suggestions?
31337 $n1p3r
PostPosted: Mon Jul 12, 2004 10:40 am
i would keep his box, then save the extra money and get a graphics card later...but not right now...prices seem to still be dropping
PostPosted: Mon Jul 12, 2004 10:45 am
Anyone know of a good transparent case w/ a power supply and LED/Cathode lights?
PostPosted: Mon Jul 12, 2004 10:49 am
Does that mobo come w/ the integrated ports that I needed?
PostPosted: Mon Jul 12, 2004 10:51 am
I really really want something w/ a window. 8)
PostPosted: Mon Jul 12, 2004 10:54 am
get a LanBoy from Antec
PostPosted: Mon Jul 12, 2004 11:01 am
hey ive seen those sweet
PostPosted: Mon Jul 12, 2004 11:04 am
is it difficult to install a Power Supply? Any suggestions on those?
PostPosted: Mon Jul 12, 2004 11:06 am
no. just put it in its spot and screw it in. plug in stuff.
just get a reputable brand name (antec, pc power and cooling, enermax, etc)
PostPosted: Mon Jul 12, 2004 11:18 am
BAH!
There's enough rice in this world without polluting lan parties! :twisted:
PostPosted: Mon Jul 12, 2004 11:39 am
"Please note this board does not come with Plastic Heatsink Retention Bracket" Is that an issue? I'm going with the LANboy case and a Antec 480W Power Supply with Blue LED Fan. Also whatever the "stock" cooling that comes with the LanBoy. I decided with a Creative Labs Sound Blaster Audigy2 ZS PCI Sound Card & a 256mb Sapphire Radeon 9600.
PostPosted: Mon Jul 12, 2004 2:28 pm
Only if you're going to use the stock HS/F. You can call newegg and they'll get you the part to add in if you want though. Otherwise, they aren't too tough to find. But aftermarket HS/F's come with their own mounting items. OMG! We never mentioned an Athlon64 cooler! I like thermalright, but can't find any that they state are compatible with that board.
How about $12 more for the A2 ZS Gamer? May be worth the extra cash if you don't have some of those titles.
http://www.newegg.com/app/ViewProductDe ... 171&depa=0
PostPosted: Tue Jul 13, 2004 4:18 am
I'd recommend the 9800 Pro, unless you are going to replace it soon. The 9600's just don't (IMO) cut the mustard.
