It is currently Tue Mar 31, 2015 8:11 pm
 Post subject: hdd space question?
PostPosted: Sun Jul 11, 2004 7:52 pm
hi all i have a maxtor 250gigs 8megs cache hdd, and windows saw it as 239gigs. i split the partitions into two. my C = 30gigs, and my D = 209gigs.
i know after all the computing the computer does, the spacing is less. for example, if you throw in a 60gig hdd, after partitioning it will come to only like 57gigs. is the 11gig drop in my 250gigs hdd normal? thanks for any replies.
PostPosted: Sun Jul 11, 2004 7:54 pm
Yes thats normal.
http://www.ultratech-llc.com/KB/?File=/disksizes.txt
PostPosted: Sun Jul 11, 2004 8:04 pm
thanks someguy, yeah i know its normal when it comes to not usin the full capacity of the hdd. but i didnt think its gonna be 239gigs after the partition was created. i thought it would be like 245gigs or something. thanks for the info.
PostPosted: Sun Jul 11, 2004 8:36 pm
250 * .93 = 232.5 GB
The larger the drive, the more space you "lose."
PostPosted: Sun Jul 11, 2004 9:55 pm
1 gigabyte doesnt = 1000 megabytes like hard drive makers thing...
its a word game...
PostPosted: Sun Jul 11, 2004 10:24 pm
thanks someguy. yeah when you posted the link to the calculations i went ahead and got a calculator and calculated the math. it comes out to the same thing you posted right now.
PostPosted: Sun Jul 11, 2004 10:26 pm
Depends on how you look at it. But yes, it is a word game.
I would explain it but the link I posted earlier says anything I would say and probably does it better anyway :P
PostPosted: Mon Jul 12, 2004 8:44 am
According to Hard Drive Manufacturers, 1GB = 1,000,000,000 bytes.
According to the rest of the computing world, 1GB = 1,073,741,824 bytes.
as you can see, that's 70 megabytes per gigabyte that is lost to Marketing.
On your 250GB drive, you lose a whopping 17GB of space.
go figure.
