It is currently Tue May 05, 2015 5:36 am
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: What types of RAM can I use for AthlonXP 1800+?
PostPosted: Sun Jul 11, 2004 8:42 am
What types of RAM can I use for AthlonXP 1800+ on an ABIT AN7 motherboard?
PostPosted: Sun Jul 11, 2004 9:00 am
Phoenix Foundation (Top 10)
Alot of info can come from the mfr website...
http://www.abit-usa.com/products/mb/pro ... &model=158
Stick some 3200 in there and youll be just fine, with plenty of room for future upgrades.
PostPosted: Sun Jul 11, 2004 9:09 am
I currently have 1GB registered PC2100 DDR SDRAM which doesn't work for the mobo. How much better is PC3200 RAM?
PostPosted: Sun Jul 11, 2004 9:14 am
Contributing Writer
Contributing Writer
Much better, considering it's compatible and will work. The PC3200 will clock down to PC2100 speeds to match your proc, but you'd be all set to drop a Barton proc in there down the line (as well as OCing headroom should you ever venture down that road). The AN7 is a nice nForce2 mobo, I wouldn't be so quick to replace it as you've been asking in other threads.
PostPosted: Sun Jul 11, 2004 9:19 am
I agree with One4yu2c.
Very nice board and the RAM allows for future upgrades. Its a shame you have that extra RAM though, im sure you could find someone in here to help you get rid of it. You might could wander over to the appraisal section and see what its worth.
PostPosted: Sun Jul 11, 2004 10:01 am
I'm thinking about going to Fry's later today to pick up 2x 512MB PC3200 DDR SDRAMs. Any brand of RAM you guys recommend at Fry's? Unfortunately, I don't have the time to wait for an online order. :(
PostPosted: Sun Jul 11, 2004 10:09 am
Ive stuck with Crucial for the longest time, and just recently started using Mushkin. Both have worked great for me. Kingston's valuram is something else ive tried for budget PCs and it seems to work ok too.
PostPosted: Sun Jul 11, 2004 10:12 am
im not sure what brands Fry's sells cuz they dont have them around here, but i suggest 1 of these: GEIL, Mushkin, Corsair, Crucial, or Kingston. But make sure u check the latency, it should be 2.5 or lower.
PostPosted: Sun Jul 11, 2004 10:13 am
Do Fry's sell Crucial RAM?
Or what brands of RAM does Fry's sell?
PostPosted: Sun Jul 11, 2004 10:14 am
I'm thinking about getting PC3200. Any specs for that I should be aware of? Or I might get PC2700.
PostPosted: Sun Jul 11, 2004 10:28 am
3200 and 2700 are usually around the same price, sometimes the 3200 is cheaper. Its best to get the 3200 that way you have the headroom for overclocking or future upgrades.
PostPosted: Sun Jul 11, 2004 12:39 pm
I'd suggest Crucial, Corsair, Kingston, Mushkin, Fry's should have Kingston or corsair for sure. Maybe crucial.
I'd get PC-3200...its usually about the same or cheaper.
PostPosted: Sun Jul 11, 2004 3:18 pm
Contributing Writer
Contributing Writer
I second the above. And I poo-poo the Geil recommendation a few posts above. I'm not a big Geil fan, and there's certainly more consistently reliable brands to choose from. I may get blasted for that, but oh well, I already poo-pood.
PostPosted: Sun Jul 11, 2004 4:10 pm
Agreed on the geil thing :)
PostPosted: Sun Jul 11, 2004 6:43 pm
I just went out and bought two Corsair ValueSelect PC3200 DDR 512MB 400MHz 184 Pin RAM. Is cost me $210 at Fry's. Did I get a good deal?
PostPosted: Sun Jul 11, 2004 6:56 pm
Contributing Writer
Contributing Writer
TsunamiZ wrote:
I just went out and bought two Corsair ValueSelect PC3200 DDR 512MB 400MHz 184 Pin RAM. Is cost me $110 at Fry's. Did I get a good deal?
If that's $110 total for 1g, then yes, you got a smoking deal. The same stuff would run you $80/512mb on Newegg ($160 total).
PostPosted: Sun Jul 11, 2004 7:46 pm
yeah pretty good deal.
PostPosted: Mon Jul 12, 2004 3:36 am
Whoops--typo! I meant I got it for $210. Is that a good deal for the type and amount of ram?
PostPosted: Mon Jul 12, 2004 4:19 am
That sounds reasonable. You could have gotten 2 sticks of Crucial for $160 including shipping from newegg, but i remember you saying you needed them right now. Sounds good too me, but if it was me i would have ordered online and saved $50. Good luck with it, youll really like the boost it gives.
PostPosted: Mon Jul 12, 2004 5:12 am
I was told that my RAM is currently limited to PC2100 speed, until I get AthlonXP 3200+ CPU to make use of the PC3200 RAM speed. I might do that in the future.
BTW: Can I really get the exact same memory for $50 less at newegg.com? Maybe I should order it, when it arrives--install it, then return my Fry's $210 set. Will they let me return the RAM?
