It is currently Tue Jan 27, 2015 1:21 pm
 Post subject: AthlonXP mobo that supports 1GB Registered PC2100 DDR SDRAM?
PostPosted: Sun Jul 11, 2004 8:30 am
Is there a current AthlonXP motherboard I can buy that supports 1GB Registered PC2100 DDR SDRAM? I have an AthlonXP 1800+ CPU.
PostPosted: Sun Jul 11, 2004 8:34 am
what is the brand name and model number for your mobo?
PostPosted: Sun Jul 11, 2004 8:38 am
ABIT AN7 motherboard.
PostPosted: Sun Jul 11, 2004 9:08 am
Dude Asus A7n8x-e deluxe and get a new processor while your at it
 Post subject: Re: AthlonXP mobo that supports 1GB Registered PC2100 DDR SD
PostPosted: Sun Jul 11, 2004 9:20 am
Contributing Writer
Contributing Writer
I wish we could condense all these threads on basically the same subject (I think we're up to 3 now). My vote goes to replace the RAM with PC3200 sticks. As mentioned in another thread, you already have a nice mobo and you'll also have upgradeability should you decide to pop a Barton in there down the line.
From what I'm gathering of these posts, I can't imagine you need the benefits registered RAM provides.
As for the proc that Sumthing546 said to replace, depending on what you do and how your system is handling things, it still has life left in it. Ideally, a Barton proc would be a utopian match for your mobo, but it's all relative.
PostPosted: Sun Jul 11, 2004 10:05 am
I don't think the Asus A7n8x-e deluxe supports registered RAM. :?:
PostPosted: Sun Jul 11, 2004 10:08 am
What is a Barton proc?
BTW: What's the difference between registered and unbuffered ram? Why is there two types?
PostPosted: Sun Jul 11, 2004 11:43 am
its a type of CPU core. there are many flavors: thunderbird, barton
it just specifies the amount of L2 cache and the like. you can do research, but barton is your best bet i think.
registered and unregistered: one has error corrections. it goes slower but is more accurate. that is my little understanding of it
PostPosted: Sun Jul 11, 2004 12:36 pm
The A7N8X does NOT support registered RAM.
As we have said in your other thread, no single proc mobo that I know of for the XP supports registered RAM.
Sell it or trade it in for unbuffered/unregistered.
PostPosted: Sun Jul 11, 2004 3:42 pm
What are the clock speeds of Barton?
PostPosted: Sun Jul 11, 2004 4:01 pm
Contributing Writer
Contributing Writer
Barton 2500+ 333fsb 1.833GHz
Barton 2600+ 333fsb 1.917GHz
Barton 2800+ 333fsb 2.083GHz
Barton 3000+ 333fsb 2.167GHz
Barton 3000+ 400fsb 2.100GHz
Barton 3200+ 400fsb 2.200GHz
--Mobile Bartons--
Barton 2000+ 266fsb 1.533GHz
Barton 2200+ 266fsb 1.667GHz
Barton 2400+ 266fsb 1.800GHz
Barton 2500+ 266fsb 1.830GHz
Barton 2600+ 266fsb 2.000GHz
Barton 3000+ 266fsb 2.200GHz
