It is currently Tue Mar 03, 2015 4:51 pm
 Post subject: Can I use registered DDR ram in unbuffered mobo?
PostPosted: Sun Jul 11, 2004 2:57 am
I have 1GB PC2100 DDR SDRAM (registered) for my AthlonXP 1800+. I just bought a new mobo (ABIT AN7 motherboard) that seems to only support unbuffered DDR. Can I use my registered DDR ram on this mobo? Or do I have to get another mobo?
PostPosted: Sun Jul 11, 2004 7:33 am
No, you can only use unbuffered RAM on your mobo.
IMO you should try to sell your registered RAM and buy some unbuffered sticks...it would be hard to find a good mobo for the AMD XP (non opteron/hammer/etc) that supports registered RAM.
PostPosted: Sun Jul 11, 2004 10:00 am
shit, i just throw everything together and try it out. if it dont boot, then sumthin's not compatible, or sumthin's messed up.
PostPosted: Sun Jul 11, 2004 10:30 am
I don't want to risk screwing anything up permanently.
PostPosted: Sun Jul 11, 2004 12:01 pm
you probably waste lots of time and money on that way of doing things
good idea..you should have done more research before purchasing your RAM . most mobos dont support registered RAM. only servers and the like for the most part
PostPosted: Sun Jul 11, 2004 3:41 pm
It's just leftover RAM from my old mobo. :(
PostPosted: Mon Jul 12, 2004 12:41 pm
King of All Voodoo2 Cards
Is it a single 1GB stick?
PostPosted: Mon Jul 12, 2004 3:10 pm
From what I gather in his other threads it is 2x512 sticks.
PostPosted: Mon Jul 12, 2004 5:51 pm
It is 2x512 sticks.
