It is currently Sun Jan 25, 2015 7:53 pm
 Post subject: 400 FSB support yes or no?
PostPosted: Sat Jul 10, 2004 2:59 pm
I was wondering if my soyo KT400 Dragon ultra will support the XP 3200 barton cpu. The Bios has the option to set the fsb to 200 mhz and the motherboard supports pc3200 ddr ram. However soyo's site claims that the max cpu fsb is 166 mhz.
Does anyone know which is correct, the bios or soyo?
Also does anyone have an xp 3200 runnng on the kt-400 chipset?
IF my motherboard won't accept the 3200 cpu then I'll just drop in an xp 3000 333 fsb, another 512mb of pc2700 ram, and a new Radeon x800 pro or Geforce 6800 and call it a day.
So hopefully the faster cpu, 1 gig of ram, and insanely fast graphics card will allow me 60 fps (Minimum) in all game types in UT 2004 with all game settings and graphic settings maxed out, and still have power to spare to run Half life 2 with decent fps (30 min) and image quality.
I don't really want to scrap my motherboard as I've had it for quite a while, but I will if I have to.
PostPosted: Sat Jul 10, 2004 3:03 pm
If I were you, I'd go with the bios rather than the manual (if that's what you're reading from soyo.
Where's the documentation of this? Care to send it?
PostPosted: Sat Jul 10, 2004 3:43 pm
Soyo's site lists the max fsb as 166, the documentation says that the motherbard supports 200/266 athlon xp's under cpu support
then under cpu fsb frequency the book lists 100 - 255 mhz for 100 and 133 fsb cpu's
PostPosted: Sat Jul 10, 2004 4:05 pm
Contributing Writer
Contributing Writer
According to their knowledgebase, it will NOT accept 400fsb Bartons:
http://www.soyousa.com/kb/kbdesc.php?id=128
Gives you an excuse to pop for an A7N8X-E or NF7-S though :lol:
PostPosted: Sat Jul 10, 2004 4:16 pm
try going with the bios since the bios is what controls all that stuff.
PostPosted: Sat Jul 10, 2004 4:29 pm
I'll bet it's an unofficial support. It doesn't seem that it can't handle it, or shouldn't for any reason.
The DFI with the same chipset can handle it, but it is -- again -- unofficial.
PostPosted: Sat Jul 10, 2004 4:32 pm
What he said
PostPosted: Sat Jul 10, 2004 4:43 pm
please tell me what happens with this, i have the same board and am looking to upgrade my CPU ...
PostPosted: Sat Jul 10, 2004 8:41 pm
like ShiftyEyedGoat said, it's unoffical support, because not every board will work with a 400MHz FSB. It's hit and miss.
It's kind of like how my ECS K7S5A Pro says it can set my RAM to PC133 (which mine is) but never works properly when I try it. It takes about 3 reboots just to be able to get back into the BIOS...
PostPosted: Sun Jul 11, 2004 12:56 am
Dude why not get a Nforce 2 mobo I've heard a few stability complaints with the dragon boards and also it doesn't lock your pci and agp slots if you wanna overclock
PostPosted: Sun Jul 11, 2004 1:31 am
serialtoon wrote:
What he said
you guys are just so damned helpful...
