It is currently Thu Feb 26, 2015 4:31 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Upgrading video card...
PostPosted: Fri Jul 09, 2004 10:52 pm
I want to upgrade my video card (currently GeForce3 Ti-500). What video card should I upgrade to for my current system?
GA-7DX motherboard
AthlonXP 1800+
1 GB ram
Enermax Whisper 350W power supply
PostPosted: Fri Jul 09, 2004 10:53 pm
how much u lookin to spend?
 Post subject: Re: Upgrading video card...
PostPosted: Fri Jul 09, 2004 11:00 pm
Astro lube 2 the MAX!
GA-7DX motherboard
AthlonXP 1800+
1 GB ram
Cheap (50-100)
Geforce FX-5200 or ATI Radeon 9200
Mid-Ranged (100-200)
Geforce FX-5900xt or ATI Radeon 9800 Pro 128MB
Mid-High (200-300)
Geforce 6800GT or ATI Radeon 9800 Pro 256MB
High-end (300+)
Geforce 6800Ultra or ATI Radeon x800 Pro/Platinum
Some suggestions for both of the competition. Whatever the budget you have.
PostPosted: Fri Jul 09, 2004 11:05 pm
how is the ATi Radeon 9600SE? it's only $70 on newegg ...
PostPosted: Fri Jul 09, 2004 11:06 pm
Hmm well I was thinking of these cards on top of my head... But I guess that can be alternative to the 9200 I listed.
PostPosted: Fri Jul 09, 2004 11:10 pm
I'm willing to spend up to $300 as long as it's a good fit for my system. I'm thinking about getting the ATI Radeon 9800 Pro (previous gen's top end card, right?). I hear ATI has the best previous gen card.
PostPosted: Fri Jul 09, 2004 11:16 pm
Hmm the Geforce 6800GT is next to near the ULTRAs. Just clocked a bit slower. Should be considerably faster than the 9800 Pro I think.
Check out some reviews. Usually on anandtech/tomshardware/hardocp website for reviews.
edit: JUST to add, check out this thread on the 6800GT. Has some links to benchies. Looks very promising.
http://www.maximumpc.com/forum/viewtopic.php?t=620
PostPosted: Fri Jul 09, 2004 11:17 pm
yeah, i wasnt saying he should go with that over what u said, i was wondering if it was better than the 9200, i heard the SEs arent so great.
PostPosted: Fri Jul 09, 2004 11:19 pm
yep. Anything SE is teh suck.
PostPosted: Fri Jul 09, 2004 11:21 pm
is it a performance difference or just an options difference?
PostPosted: Fri Jul 09, 2004 11:22 pm
performance wise. they kill it by clockrate, and some options.
PostPosted: Fri Jul 09, 2004 11:23 pm
ahh, so would it be better to get a 9200Pro over a 9600SE?
PostPosted: Fri Jul 09, 2004 11:25 pm
IMO I would put a 9800 Pro 128MB in your system.
Should fit in nicely. If I ever get some cash that's what Im probably going to move to (or whatever is in my pricerange down the line).
PostPosted: Fri Jul 09, 2004 11:27 pm
i dunno. haven't checked any benchies on any of the low end. they suck. so not much to say.
PostPosted: Fri Jul 09, 2004 11:28 pm
I can't go with the current gen cards such as 6800 and X800 because those require huge power supplies, and my CPU would also be a bottleneck. I want a card that is a good fit for my system. I don't want to upgrade any other components to make the new video card work. Also, I think my GA-7DX only supports AGP 4x (not sure).
PostPosted: Fri Jul 09, 2004 11:31 pm
See my post above ;)
PostPosted: Fri Jul 09, 2004 11:32 pm
ahh, ok, thanx for the help.
PostPosted: Fri Jul 09, 2004 11:33 pm
well aslong you don't got 3-4 HDs, 2+ optical drives, you should be well and fine with a 6800Gt card. and x800 Pro.
The minimum is a 350watt ps.
And if you buy one of the new mobos I suggested you should be fine.
Plus you got a good brand name powersupply so it should do fine.
But up to you, on which one you wanna buy.
PostPosted: Fri Jul 09, 2004 11:53 pm
Well, minimum 350W ps is cutting it close. And my CPU is a huge bottleneck so it wouldn't be a good choice to upgrade to current gen. I think I should get the 9800 Pro. Should I be aware of any mobo spec requirements before buying it?
PostPosted: Fri Jul 09, 2004 11:57 pm
as long as the voltages match and ur mobo supports 8X AGP, u should have no problem ...
