It is currently Tue Apr 21, 2015 12:56 am
 Post subject: BIOS upgrade killed my mobo?!?
PostPosted: Fri Jul 09, 2004 10:12 pm
http://www.giga-byte.com/MotherBoard/Fi ... a_bios.htm
I was upgrading the BIOS for my GA-7DX mobo tonight using @BIOS utility. I was upgrading from version F5 to F8. Everything went fine, but upon reboot, my system power light blinks constantly and the pc speaker keeps beeping! My system won't boot up anymore! I did use the right BIOS upgrade for my mobo. This shouldn't have happened because I made sure everything was correct!
So is my mobo dead now? If I need to buy a mobo tomorrow to replace my GA-7DX, what mobo model should I buy? And upon replacing my mobo, I should be able to get my system back up and working w/o a reformat, right??
My computer system specs are:
GA-7DX motherboard (may have died from BIOS upgrade)
AthlonXP 1800+
1 GB (2x512) PC2100 DDR SDRAM
GeForce3 Ti-500
60 GB Seagate Barracuda HD
Intel network card
350W Enermax Whisper power supply
WinXP Home
I might need to buy a new mobo ASAP, if there is no way to fix my mobo. So I need some really good recommendations. Thanks!
Link to initial upgrade thread before my mobo died: http://www.maximumpc.com/forum/viewtopic.php?t=622
PostPosted: Fri Jul 09, 2004 10:32 pm
i posted about this in the last topic u posted this in, but did u reboot or did it lock up during the Flashing process? that will kill ur motherboard, but it is fixable, just not by u unless you have a removable BIOS chip, and you will have to order a new 1 from the company.
PostPosted: Fri Jul 09, 2004 10:38 pm
The flashing went fine. It even said I can reboot the computer for the new BIOS to take effect. It just when I attempted to reboot that it wont reboot. :\
Any recommendations for a new mobo based on my system specs? I don't have time to wait on an order (even if my BIOS chip is removable--which I don't know yet). Might just go to Fry's for a new mobo.
PostPosted: Fri Jul 09, 2004 10:41 pm
all i can tell ya is the 1 i have which should work fine with all those components. it's a SOYO KT400 Dragon Ultra.
PostPosted: Fri Jul 09, 2004 11:11 pm
My AthlonXP 1800+ CPU is from late 2001. Does that matter?
PostPosted: Fri Jul 09, 2004 11:12 pm
Astro lube 2 the MAX!
Well if it went fine, try clearing your CMOS. If that doesn't work, maybe take out battery for a good while then try.
If you want to upgrade to a new mobo, I would suggest:
Abit NF7-S
or
Asus A7n8x-E
Both are cheap. 80-90 dollar range. SATA-RAID, Soundstorm, LAN, etc.
Or not sure if they are released or not, the Nforce2-GB boards. Not sure on the model if I quote correctly, but supose to have onboard hardware firewall, gigabyte lan incorporated.
PostPosted: Fri Jul 09, 2004 11:19 pm
yeah, i would go with his suggestions over mine, they have more options.
PostPosted: Fri Jul 09, 2004 11:48 pm
wiseoracle's mobos? Or the CMOS idea?
PostPosted: Fri Jul 09, 2004 11:50 pm
try the CMOS idea, if it dont work, go with his mobos
PostPosted: Sat Jul 10, 2004 12:55 am
After I jumped the CMOS, the computer won't reboot until I jumped it back to the defaults. Did I clear my CMOS?
I'm trying the take out battery method now.
PostPosted: Sat Jul 10, 2004 3:08 am
Looks like I'll have to buy a new mobo. :(
Do I need to buy anything else when I buy my new mobo? Do I need to buy a CMOS battery for it, etc.? Or does it come with everthing I need? Thanks.
PostPosted: Sat Jul 10, 2004 3:14 am
Abit NF7-S
or
Asus A7n8x-E
I have 2x512 PC2100 DDR SDRAM. Will that work with those mobos?
