It is currently Sat Apr 25, 2015 9:22 pm
 Post subject: Where to connect the HDD LED lead...
PostPosted: Fri Jul 09, 2004 9:05 pm
O.k., This has been frustrating me for awhile and I've finally decided to ask... Where do I connect the HDD LED lead on my A7N8X Deluxe??? I checked my manual and the downloadable manual from Asus. It doesn't say anywhere.
They only list the following leads on the System panel connector: Power LED, Keyboard Lock, Speaker Connector, SMI Lead, ATX Power Switch, Reset SW.
My case has one labeled as HDD LED as I'm sure most cases do, WTF?
PostPosted: Fri Jul 09, 2004 9:39 pm
On the A7N8X it's called the IDE LED or IDE Activity LED.
Look at page 25 in your manual.
In any case, it's located on the bottom front corner of the mobo where all those other pins are. I'm pretty sure it's etched into the mobo too. On mine there is a round black plastic thing-a-ma-jig and the LED pins are located just above and to the right of it. They are vertical.
PostPosted: Fri Jul 09, 2004 10:02 pm
Will plugging it into teh 1 labeled "FAN" give it mure perfornence? I have a jumper on mine.
Sorry. I just checked in and had to write something...I'm eager to post! Weeeeeee!
PostPosted: Fri Jul 09, 2004 10:11 pm
LOL try it and tell us how that worked out for you ;)
PostPosted: Sat Jul 10, 2004 6:18 pm
:D Sweet, thanx... finally after all those months :wink:
