It is currently Sun May 03, 2015 3:59 am
 Post subject: Upgrading Mobo BIOS? = Went wrong??
PostPosted: Fri Jul 09, 2004 7:17 pm
http://www.giga-byte.com/Motherboard/Su ... GA-7DX.htm
I am trying to upgrade my GA-7DX AthlonXP mobo BIOS to version F8. I downloaded the file and it extracted three files:
7DX.F8
autoexec.bat
FLASH879.EXE
But when I run autoexec.bat or FLASH879.EXE, it tells me my chipset is not supported. Basically, I can't update my BIOS (which is currently F5). Can anyone help? Thanks.
Running WinXP Home, AthlonXP 1800+.
PostPosted: Fri Jul 09, 2004 8:10 pm
Contributing Writer
Contributing Writer
Have you tried using the Live Update utility?
http://www.giga-byte.com/MotherBoard/Fi ... a_bios.htm
PostPosted: Fri Jul 09, 2004 8:35 pm
I just performed the BIOS update using the @BIOS utility and it tells me it's updated and I should reboot. But upon initiating the reboot, my computer won't boot, but instead the power light blinks constantly and the system is beeping! What's going on? Did the utility just f* up my computer?!! Everthing went fine until I tried to reboot! I even used the correct BIOS for my mobo!
PostPosted: Fri Jul 09, 2004 9:27 pm
If my mobo is now dead, what mobo should I buy tomorrow to replace it?
PostPosted: Fri Jul 09, 2004 10:26 pm
if it locked up during the flash, yeah, ur motherboard either needs to be returned to the manufacturer if it's still under warranty or u can maybe get a new BIOS chip if urs is removable. that happened to my old ASUS board, it didnt have removable BIOS chip tho, but it was still under warranty. i sent it in and got it back and then it started fuckin up again tho so i just got a new board.
PostPosted: Fri Jul 09, 2004 10:30 pm
How can I check if my BIOS chip is removable? And where can I purchase a replacement chip?
BTW: All my HD data is still intact, right??
PostPosted: Fri Jul 09, 2004 10:35 pm
HD data should be still intact if that's the problem. umm, look at ur mobo to tell if the chip is removable, it will be in a lil socket. purchase a new chip from the manufacturer.
PostPosted: Fri Jul 09, 2004 11:14 pm
Astro lube 2 the MAX!
Your bios chip is either a big rectangle lookin chip usually with the BIOS name sticker on it. Or a mini square one in a brown socket.
PostPosted: Sat Jul 10, 2004 3:39 am
It has a sticker on it and is not removable. Got to buy a new board. :(
PostPosted: Sat Jul 10, 2004 6:02 am
Contributing Writer
Contributing Writer
Yikes, that's not supposed to happen! Give clearing the CMOS a try and see if it reboots afterwards:
http://tinyurl.com/3x23n
PostPosted: Sat Jul 10, 2004 11:12 am
that sucks man...
one time I was flashing the BIOS on my old FIC AZ11, and I found out the hard way my floppy drive was shit. luckily though, FIC's mobos will let you boot from a floppy, even with a bad BIOS, it saved me a motherboard.
PostPosted: Sat Jul 10, 2004 3:44 pm
Took out the battery for hours to clear the CMOS. Didn't work. :(
PostPosted: Sat Jul 10, 2004 4:39 pm
if it wont boot, the only way ur gunna get any use out of that board again is if u send it back to the manufacturer. and if it's not under warranty, it's probly not worth it.
