It is currently Sat Mar 28, 2015 9:57 am
 Post subject: k8v deluxe bios problem
PostPosted: Fri Jul 09, 2004 12:49 pm
right now im running a beta bios because the one that came with it was bad, ive been having troubles with it and wish to flash it, but the site says follow specific instructions from instruction page, but i cant find them for my motherboard, whats with this?
PostPosted: Fri Jul 09, 2004 2:39 pm
try google and see what you can come up with. good luck
PostPosted: Fri Jul 09, 2004 10:56 pm
  • If we knew the motherboard, we could possibly help
  • listing the "problems" you had and why you think the original BIOS is bad is worth a few pennies.
  • If this were posted in a Help-type thread (i.e. "Free Clinic"), then maybe more would come in and try to help ya out.
 Post subject: Re: k8v deluxe bios problem
PostPosted: Fri Jul 09, 2004 11:05 pm
Astro lube 2 the MAX!
Make sure you always check, sometimes there are different bios flash for different revisions on the same type of board.
Usually most bios directions are:
1. Download/Unzip the file
2. Download probably the AWARD bios flasher.
3. Reboot with a bootdisk (ie: WIN98 bootdisk. or www.bootdisk.com)
4. Insert the floppy with the BIOS updates
5. Run the award (or equivelant flasher proggie)
6. Type in the BIOS update name to flash. (ie: ABITKV8_01.bin)
7. Should be self explanatory.
OR if you don't want to go oldschool, newish way is:
1. Download Abit's Flashmenu and use that to flash it.
Make sure you don't got any other programs running while doing this.
But seriously, there are directions on abit's website.
