It is currently Fri May 24, 2013 7:31 am
 Post subject: computer
PostPosted: Fri Jul 09, 2004 11:45 am
can someone plz help me on how to build up a sick computer. mainly for gameing
thnx :D
PostPosted: Fri Jul 09, 2004 2:57 pm
Chief Surgeon
Chief Surgeon
Do you want to upgrade an existing, or build a new one from scratch?
Inquiring minds want to know. :) In other words, we need more info: type of games, budget, existing components, timeframe, longevity of this unit.
Thanks,
SC64
PostPosted: Fri Jul 09, 2004 6:27 pm
we definitely need more info. is gaming the only thing you gonna do with your comp? right now the AMD FX cpus ar really good for gaming. wait a bit because there are some good goodies coming out like PCI-Express and much more. for videocards check out the ATI 800Xt and the geforce 6800 series videocard. expensive videocards but if you got the money, then hey...........
 Post subject: Re: computer
PostPosted: Fri Jul 09, 2004 8:42 pm
thnx :D
Ummm... how much $$$ you want to spend is the main question :? Are you asking how to build one build one or asking what parts to use?
Check this MaximumPC link out if you haven't already.
PostPosted: Fri Jul 09, 2004 10:21 pm
thnx :D
Pretty easy. Get any ol' PC (try garage sales for bargains), Install AOL, then visit overseas pr0n sites. That should make it purdy sick...
I'll jump back in for another few cents when we get the real info:D
PostPosted: Fri Jul 09, 2004 11:17 pm
Astro lube 2 the MAX!
lol. good suggestion there chumly
Users browsing this forum: Google Adsense [Bot] and 2 guests
