It is currently Sat Feb 28, 2015 4:46 am
 Post subject: AMD L2 cache?
PostPosted: Fri Jul 09, 2004 9:26 am
Smithfield*
Smithfield*
Back when i started looking at purchasing a processor AMD had 64's up to 3400+ and the higher level ones all had 1MB L2 cache. Now with more models released some of them have a mere 512KB L2 cache. Why would AMD do this and does the 1MB have a big advantage over 512KB?
 Post subject: Re: AMD L2 cache?
PostPosted: Fri Jul 09, 2004 9:53 am
Yeilds.
If AMD makes a 1MB L2 cache CPU part os whose cache fails validation, they can just disable 1/2 of the cache and sell it as a 512K L2 model.
AMD is also making a straight 512KB L2 version of the Ath,on 64 (Newcastle) since it's die size is ~40mm^2 smaller, which increases the number of dies per wafer, increasing yeilds and therefore profits.
Plus, with the Athlon's cache architecture and the ODMC, the lack of cache hurts it far less than one would expect.
PostPosted: Fri Jul 09, 2004 11:26 pm
Astro lube 2 the MAX!
For affordability. This would be their "low" line sorta cpus. If you don't got the big bux +400 bux, then you'll have to settle with a decrease in cache memory and lil' bit cheaper.
AMD already has another CPU that will replace Newcastle, with even a smaller core, less heat and cheaper.
