It is currently Tue Apr 21, 2015 8:43 pm
 Post subject: I got MSI K8N Neo 64Bit mobo and 10k raptor, wont boot help!
PostPosted: Thu Jul 08, 2004 9:30 pm
yeah i just recently got a msi k8n neo motherboard and a amd athlon 64 3400+ proc... its been running fine with my 120gb WD SE... but i recently tried to instal a 74gb 10k SATA raptor and everytime i install the operating system and try to boot, it says that there was a error while loading the operating system, and ive tried 2 different xp discs thinking it may be the cd-rom, but its not... so does anyone know what may be the problem
PostPosted: Thu Jul 08, 2004 9:57 pm
Did you remove your old 120GB HD or added the SATA raptor along with it? If you added it, check your jumpers and boot sequence in the BIOS.
EDIT: Actually do it for both.
PostPosted: Thu Jul 08, 2004 10:44 pm
i did make it the first boot device, and itll try to boot from it, but it still says there was a error..... and i even installed the SATA drivers on the floppy it came with
PostPosted: Thu Jul 08, 2004 11:58 pm
So you fully installed winxp on the sata drive? or it doesn't let you install xp either? You did format and partitioin the new drive right? I'm not sure what else it could be... sorry
PostPosted: Fri Jul 09, 2004 4:32 pm
it installed and everything, cause when i boot from my normal pata drive i can still access the SATA drive, and i see all the windows files on there, but for some reason it just wont boot the drive, it keeps telling me there was a error, could it be a 32-bit and 64-bit incompatibility?
PostPosted: Fri Jul 09, 2004 5:23 pm
Check to see if there are any BIOS updates for your motherboard..maybe MSI has released a more stable/compatible BIOS revision for your board which might address the SATA boot problem.
Also, if you have your PC overclocked, try backing down to default speeds and booting.
Wish I could help ya more, but I'm still on a PATA drive until my SATA comes in, so no much personal experience with them.
PostPosted: Fri Jul 09, 2004 10:29 pm
OMG...why is so hard to post "HELP ME" questions in the FREE CLINIC where it belongs!? It's quickly becoming my pet peeve!
