It is currently Fri Apr 24, 2015 5:03 pm
 Post subject: Can I make my Logitech keyboard/mouse Mozilla-compatible?
PostPosted: Thu Jul 08, 2004 7:38 pm
I just purchased a Logitech MX keyboard/mouse combo and I'm trying to make full use of all the custom keys and buttons. I'm having a problem getting some of the buttons to work with Mozilla Firefox, like the back/forward buttons on the mouse, and any keys mapped to take me to a website, like the shopping and search buttons. They work fine with IE, but not Firefox. Is there any way getting this setup to work?
PostPosted: Thu Jul 08, 2004 9:01 pm
I also have the MX Duo, and had some problems browsing with my mouse. I was having problems using the middle mouse button with Firefox AND IE. I ended up just uninstalling the stupid MouseWare software and everything works fine now. I would try uninstalling it and seeing if it works. The MouseWare isn't all that great anyways.
As far as using the keyboard features with Firefox, same goes for me also... :? sorry.
Hopefully Logitech fixes this with updates on the software used or someone can tell us what to do.
PostPosted: Thu Jul 08, 2004 9:51 pm
Yep.
Interestingly enough the MS XP drivers seem to do a better job than Logitech's.
I also had issues with the software that came with my MX500.
I also never installed the Intellimouse software MS packages...usually I just used the XP drivers.
