It is currently Fri Feb 27, 2015 1:42 pm
 Post subject: More souncard info
PostPosted: Thu Jul 08, 2004 10:07 am
Ok guys, I just bought a soundblasterlive Audigy 2 zs...i was using the mobo's onboard sound( Abit IC7-max3) my question is, when I install the soundcard, should I leave the soundrivers for the mobo on the PC, or should I delete them and strictlly deal with the soundblaster drivers?
peace
 Post subject: Re: More souncard info
PostPosted: Thu Jul 08, 2004 10:26 am
peace
Delete them. There's no harm in leaving them there, but there's also no point in keeping them either. I mean, you're never going to use the onboard sound anymore so just dump it.
Make sure you disable it in the BIOS
PostPosted: Thu Jul 08, 2004 2:19 pm
you can leave the drivers there. just disable the onboard sound in the bios.
