It is currently Sat Jan 31, 2015 4:24 am
 Post subject: Reccommended Rechargeable Batteries for Digital Camera?
PostPosted: Thu Jul 08, 2004 9:30 am
Hey everyone,
I finally got a decent sized CF card for my new Canon A80, now I'm wondering, what are some good rechargeable batteries for it?
I seem to remember reading that anything over 2100MAh (sp?) was supposed to be fine. But is that true? Is there not really a difference between brands, just so long as you buy at or above that spec?
Any advice is MUCHO appreciated.
Thanks!
PostPosted: Thu Jul 08, 2004 9:34 am
I have an Olympus C5050 with a big memory card and use RayOVac 2100 mAh batteries. I've YET to run the batteries down before I fill up the card, and I take between 100-200 pictures per day. Hope this helps.
PostPosted: Thu Jul 08, 2004 10:32 am
Any Nickel-Metal Hydride (Ni-MH) with 2100mAh should do you good. Make sure you get a good charger to go with it.
PostPosted: Thu Jul 08, 2004 2:20 pm
King of All Voodoo2 Cards
Don't buy any of the Mercury branded NiMH batteries, I got a few of these POS's and they only lasted about 2 months.
I switched to the 2100mA Panasonic NiMH and never looked back.
PostPosted: Sat Jul 10, 2004 2:23 pm
Phoenix Foundation (Top 10)
Ive got an HP camera..couple years old. I use the Rayovac 15min charger and batteries. Works great, havent ran them out yet while ive been out taking pictures. I always come back home and throw them on the charger so there ready to go the next time i need them. Highly recommend them.
PostPosted: Sat Jul 10, 2004 6:50 pm
does your camera support crv3 batteries? if so they have recharable ones you can find online that run around $45i would like to get them but not yet i currently use the ones that come with my olympus c-750 ultra i also use energizer 1850mah and they last preaty long
PostPosted: Sat Jul 10, 2004 9:00 pm
I dont even know what that is, lol. I put 4 AA batteries in it and it works, all i can tell ya. Are those a special type of battery that last longer or something?
PostPosted: Sun Jul 11, 2004 6:15 am
like a rock - waitaminute, I AM a rock
http://www.thomas-distributing.com/
They have 2400mAh NiMH AAs for under $14 per 4-pack. I get all my rechargables from this site. Although it looks like a 5th grader made the site they have yet to let me down.
As a plus they're environmentally friendly.
PostPosted: Mon Jul 12, 2004 11:26 am
Sweet Link, I think I may pick a few of them up and test them out.
