It is currently Sat Feb 28, 2015 9:03 pm
 Post subject: Sound Question
PostPosted: Thu Jul 08, 2004 7:32 am
Hi guys, I currently have an Abit IC7-Max3 mobo, with on board sound..it supports 5.1 surround. Would i see a performance difference if I installed a Creative Labs Sound Blaster® Audigy® 2 ZS Sound Card, or should I stick with on board?
PostPosted: Thu Jul 08, 2004 8:16 am
The difference will be huge. Not only will the sound quality improve drastically, but your framerates will also jump up because the CPU won't have to do all the audio work too.
Ditch that onboard sound as fast as you can...
Hell, even a SB Live! is better than onboard sound!
 Post subject: Re: Sound Question
PostPosted: Thu Jul 08, 2004 8:17 am
Contributing Writer
Contributing Writer
This is a little vague on what you consider to be "performance," but in terms of CPU utilization and sound, there should be a noticeable difference in both. In terms of sound, that's dependant on the quality of your speakers as well, and how critical your ears are.
The simple answer is, if you're a gamer, the Audigy 2 ZS is the card to have.
PostPosted: Thu Jul 08, 2004 8:22 am
Thats what I thought, Im gonna go get that siound card today....one more question, My case has a USB, Headphone jack on the front & top..the front is connected , & is only USB..the top is not connected, cause i was not sure if I need to connect it to my mobo or the soundcard. any advice would be awesome.
