It is currently Thu Feb 26, 2015 3:54 pm
 Post subject: Purchased new Hard Drive...
PostPosted: Thu Jul 08, 2004 7:13 am
I just ordered the Western Digital 740GD Hard Drive, and I have 2 questions:
1) Can anyone recommend backup software?
2) Can anyone recommend a Parrallel ATA to Serial ATA adaptor, or do you think I should just get a new mobo?
Thanks in advance.
PostPosted: Thu Jul 08, 2004 7:59 am
1. No idea, I just copy and paste.
2. What motherboard/CPU do you have?
PostPosted: Thu Jul 08, 2004 8:07 am
My Motherboard is the MSI KT4V
http://www.msi.com.tw/program/products/ ... EL=MS-6712
PostPosted: Thu Jul 08, 2004 8:11 am
Actually, it is the KT4V-L (onboard 10/100 LAN)
PostPosted: Thu Jul 08, 2004 8:17 am
look up Dantz Retrospect. I hear that's a top notch program.
PostPosted: Thu Jul 08, 2004 8:49 am
I personally just cut and paste as well but there are a few good programs out there. As mentioned, Dantz Retrospect is supposed to be great and Norton Ghost isn't bad either. THe problem with Ghost is that it makes and image that you would restore from in an emergency. If I remember correctly it's not possible to recover just one or two files from the image though. That's the major downfall of Ghost. On the other hand it can back up to cd/dvd/or other hard drives which is a nice set of options.
PostPosted: Thu Jul 08, 2004 9:07 am
Norton Ghost is a good back up program
PostPosted: Thu Jul 08, 2004 10:37 am
If you're planning a system upgrade soon, I'd just buy whatever SATA/PATA converter you can get your hands on (or a SATA card), but if you are going to keep that CPU/RAM for a while, then a new Mobo might not be a bad idea.
