It is currently Mon Mar 30, 2015 5:54 am
 Post subject: Computer case front firewire
PostPosted: Wed Jul 07, 2004 12:15 pm
I am building a new system. My Chieftec Aluminum case :D has front USB2 and Firewire ports with wires to connet to the motherboard. My MB, (MSI PT880 NEO) only has USB2 connections on the board itself, no firewire. My PCI firewire card has a standard internal 6 pin male connector, but the plug from the case front is intended for the MB and is not compatible. :cry: Is there converter available? Any suggestions? :?:
PostPosted: Wed Jul 07, 2004 12:19 pm
you could gut out the connector at the end of the cable and put on a firewire connector on the end, if you can find the correct wiring scheme...
PostPosted: Wed Jul 07, 2004 12:32 pm
yea, if you find a wiring diagram on the net, you should be able to cut the end of of a firewire cable and splice it to the front panel connectors and be set.
PostPosted: Wed Jul 07, 2004 1:22 pm
Thaks. I hadn'y yhought of that. I have the wiring scheeme, twisted pair etc., seems simple enough. An adapter would be nice though. :D
