It is currently Mon Mar 30, 2015 9:30 am
 Post subject: fan problem
PostPosted: Tue Jul 06, 2004 2:53 pm
my front case fan and my side window fan stoped working.. does anyone know what could be causing that problem.. thanks
PostPosted: Tue Jul 06, 2004 3:18 pm
Try plugging them into another plug, spin them with your hand and see if they spin freely, coulda blown a bearing or something.
Could just be that something fried inside just go pick up some new ones and letter blow
-Brad
PostPosted: Tue Jul 06, 2004 4:10 pm
dead fans?
plug them into another connection on the mobo
another connection directly into the PSU
 Post subject: Re: fan problem
PostPosted: Wed Jul 07, 2004 12:02 am
Astro lube 2 the MAX!
could just be it collected so much dust they just stopped period. I know one of my fans was bad. Just manually turning it was harder to move than normal. I found that the greese in it dried up. Got some veggie oil, and it relubed itself and it runs like the day I bought it. Maybe you just need to clean it up and lube it.
PostPosted: Wed Jul 07, 2004 5:39 pm
my two cents... if the fans are over a year old, replace them. They're cheap and it's worth it.
As a side note, if you do end up replacing them, I have some panaflow fans that are close to 3 years old that are still humming (almost silently) along in a system that is up on a 24/7 basis.
PostPosted: Wed Jul 07, 2004 6:14 pm
have you ever cleaded your system? if not the dust probably got them. its cheap to replaCE them and you could add some flare by getting some led fans.
PostPosted: Thu Jul 08, 2004 10:26 am
Good point Athlon...
At least twice a year, open your system up (make sure it's powered off) and use some compressed air to blow out the fans, heatsinks, powersupply, hard drive cage, etc. Then use a vacuum to suck up the roaming dust bunnies.
If you have fur-bearing pets, probably wouldn't hurt to do it more often.
PostPosted: Thu Jul 08, 2004 2:16 pm
ask for help in "free clinic"
