It is currently Tue Jan 27, 2015 3:16 pm
 Post subject: Onboard RAID
PostPosted: Mon Jul 05, 2004 10:14 pm
How long does it take for the different RAID controllers to scan the hard drives?
The Promise controller on my Gigabyte 8INXP seems to take forever, but the High Point 374 on my Epox 4PCA3+ only takes a few seconds.
I'm thinking about replacing the 8INXP with an 865 or 875 board. Getting tired of waiting for it to boot. I'm leaning towards another Epox or a DFI Infinity because they use High Point.
Any one have experience with any other RAID controllers?
PostPosted: Tue Jul 06, 2004 12:08 am
the raid 0 on my asus p4p 800 is via (ide)and it boots fast as hell, maybe 2-3 seconds on the raid screen.
But yes, my FIC board had a promise raid controller on it, and it took a lot longer.
Um can utell me if promise cards take that long?
Anyways promise's raid doesnt nearly take as long as SCSI does. My dual channel scsi mobo has to scan through for 30 hdds (15 for each channel) b4 it will finish its screen.
PostPosted: Tue Jul 06, 2004 2:43 am
I have a Gigabyte 8IHXP and it takes a while too. May be the brand:p
It's up for appraisal if anyone cares to look in that folder;)
PostPosted: Tue Jul 06, 2004 2:54 am
INFINITE vCORE
INFINITE vCORE
I've noticed that my onboard sATA controller takes longer to do the drive detection in RAID mode...
As for the boot delay I'm running the onboard sATA with two drives in RAID, an ATA66 controller, plus two SCSI cards :)
Can you say delay?
PostPosted: Tue Jul 06, 2004 4:07 am
i could try out my onboard RAID if i had another drive to put there ... anybody wanna donate 1?
PostPosted: Tue Jul 06, 2004 9:48 am
Thats a little misleading.
SCSI doesnt take forever to scan them. The fact that you have 30 HDDs on there is what makes it slow (as you know). Just because YOUR SCSI setup takes a long time to scan, doesnt mean ALL SCSI setups take forever.
PostPosted: Tue Jul 06, 2004 10:33 am
no there isnt 30 drives on it.
what it does is it scans from # 1-15 for each channel.
I have that and an adaptec 29160 and that takes a while too
well forever for me is 15 secs added. some people can be okie with that, i cant :(
PostPosted: Tue Jul 06, 2004 11:14 am
Astro lube 2 the MAX!
takes only a couple seconds for me. and i have 2 controllers. promise and the silicon sata. 2-3 seconds and straight to XP screen.
PostPosted: Fri Jul 09, 2004 9:01 am
What mobo you got?
Does any one have a Giga RAID controller? I think it's proprietary to Gigabyte boards.
PostPosted: Fri Jul 09, 2004 12:58 pm
Have you checked the SCSI BIOS to see if there is a way to tell it to skip unused channels or something like that?
