It is currently Fri Jan 30, 2015 3:16 am
 Post subject: PC Locks Up!
PostPosted: Mon Jul 05, 2004 5:19 am
Hi Everyone,
I am new to the forum and have a question. I like to play the Hoyle Table games. Sometimes when I play Parchesi I get this awful sound (cracking and popping) and the comupter locks up. I have to turn it off and then back on. It seems to happen only when I play this game. I am wondering if maybe I need a new sound card? Maybe this game just pushes it to the limit. Has anyone had this kind of problem? Help, please!
Thanks :idea:
PostPosted: Mon Jul 05, 2004 6:14 am
well what system are you runing?
and what os?
PostPosted: Mon Jul 05, 2004 7:00 am
http://www.vugames.com/downloadfile.do? ... diaid=8889
Do you have patch installed?
PostPosted: Mon Jul 05, 2004 7:13 am
I am running an AMD Athlon XP 2000+
1.67 GHz with 1.00 GB of RAM and Windows
XP Pro. I think I have all the latest drivers installed.
My sound card is a Sound Blaster Audigy.
I just went to the site for the patch. I had no idea that was available.
Thanks
PostPosted: Mon Jul 05, 2004 7:55 am
if there are any patches available, install them and see if it works for the game. good luck
PostPosted: Mon Jul 05, 2004 8:21 am
I will let you know if I have any more problems with it.
Thanks again. :D
 Post subject: Re: PC Locks Up!
PostPosted: Mon Jul 05, 2004 12:38 pm
Mercedesladie wrote:
Hi Everyone, I am new to the forum and have a question.
Let's try to follow the format and post troubles that we're trying to fix in the "Free Clinic". It's new and I know we don't have a start page to explain the methods of madness, but it works. We're all better off because the help is more abundant in a section dedicated to helping others.
Spread the word, tell your friends. Thanks :P
PostPosted: Mon Jul 05, 2004 12:50 pm
Thanks, I'll remember that next time. :wink:
PostPosted: Mon Jul 05, 2004 1:45 pm
more details?
PostPosted: Mon Jul 05, 2004 3:04 pm
I think the patch may have fixed the problem. I will keep you posted.
Thanks
