It is currently Fri Mar 06, 2015 9:14 pm
 Post subject: Voltage on Athlon XP
PostPosted: Fri Jul 02, 2004 6:23 pm
i have a barton 2500+ and was wondering if it would be safe to put the vcore up to 1.775v. according to the ABIT EQ it only gets 1.71v when the vcore is set at 1.75v so if i set it up it should get around 1.73-1.74v. i do notice that this new board puts out less volts than my old one becaue at 1.75v on my old one i was able to oc to 2209mhz and run the prime95 torture test for 48+ hours completely stable, but on this new board with all settings identical to the other board it will only run for 6 hours stable. would it be safe to increase the vcore to 1.775?
PostPosted: Fri Jul 02, 2004 8:04 pm
i would step it up little by little, not all at once
PostPosted: Fri Jul 02, 2004 8:57 pm
Yeah, if you can do slower steps, I would definitely do that instead of jumping all the way to 1.75v.
PostPosted: Sat Jul 03, 2004 6:25 am
well, i did step it on my old board and found i had to have it at 1.75v. on my old board it delivered right around 1.75v but this new one only gives 1.71-1.73v when its set for 1.75v. thats why i was wondering if it would be safe to put it t 1.775v because that way it would be close to the 1.75v my old board deliverd, which my cpu handled perfectly.
PostPosted: Sat Jul 03, 2004 7:05 am
The reason I say that is for all we know, the board might actually put out 1.775v when you select that.
So take it a little slower and watch your voltages.
PostPosted: Sat Jul 03, 2004 7:11 am
well, the bios reports tht is getting etween 1.74-1.76v when set at 1.75v, so i decided to clock down rather than increase the voltage.
