It is currently Tue Apr 21, 2015 11:59 am
 Post subject: Average Athlon 64 temp?
PostPosted: Fri Jul 02, 2004 6:35 pm
What kind of temps is everyone with a Athlon 64 seeing? At idle, I'm seeing 42-44 Celcius. Coming from an Intel system, I don't know if this is normal or not. I have not witnessed it going above 50 in gaming or 3DMark, but I want to overclock it some, so I'm just checking.
Athlon 64 3500+ (Thermalright SLK48U and Vantec Tornado 92mm fan)
Abit A8V
Corsair XMS 1 GB dual channel PC3200
Radeon 9700 Pro
Audigy 2
PC Power & Cooling 510 Deluxe
Caseflow is adequate (2x80mm Tornados intake;1x80 Tornado, 1x20cfm slot cooler and 1x120mm Vantec Thermalflow exhaust)
PostPosted: Fri Jul 02, 2004 9:12 pm
Dunno what the average is for A64s, but generally speaking, for procs, those are good temps.
If you start hitting 50C+, then Id say you might want to look into a better cooling solution (different heatsink, higher CFM case fans, fan placement, etc).
PostPosted: Fri Jul 02, 2004 10:02 pm
whitepapers probably say like 85C is the max...you are good
PostPosted: Fri Jul 02, 2004 10:07 pm
It's the max, but you'll see problems before you hit 85C...
Not to mention, the lower the temp the better (well, to a certain extent).
PostPosted: Fri Jul 02, 2004 10:10 pm
athlong 64 is what, 102watts? something like that...it would be around 50...
also, i know that is the MAX before things start to melt.
PostPosted: Sat Jul 03, 2004 6:04 am
Max [Ph]otographer
Max [Ph]otographer
That is a good temp.
I've got an AMD Barton 2500+ oc'ed by 100mhz that I can't seem to keep below 50C without removing the side of the case :(
I'm gonna shut this thing down for about an hour, I put in some AS5 yesterday and haven't shut it down since. From what I've read, the system needs to be shut down for a couple hours a day for the stuff to really work in. Then the temps should drop up to 5C.
Dan O.
PostPosted: Sat Jul 03, 2004 6:38 am
Well, I ran SETI@Home while I was sleeping, and the temps worked their way back up to 50. Of course, the room was about 4-5 degrees warmer. I imagine SETI is a pretty CPU-intensive program though.
PostPosted: Sat Jul 03, 2004 7:07 am
Max [Ph]otographer
Max [Ph]otographer
Try folding and see what happens:
http://www.stanford.edu/group/pandegroup/folding/
That thing will suck all of your CPU power, I believe it will no matter how powerfull your CPU is. My CPU has been at 100% ever since I started folding, it's using 98% of my CPU all by itself.
Dan O.
