It is currently Fri Feb 27, 2015 5:16 am
 Post subject: Question on Power Supply for a Dell System
PostPosted: Fri Jul 02, 2004 1:52 pm
I want to know if I upgrade from 250 watt to a 400watt power supply for my dell system, which has to have a special one at that, will help over proformce any? I use my pc for gaming and muti-media. If I want to buy a power supply what company sould I get one from?
My System;
Dell model 8250
2.4ghz
768 Rdram PC1066
ATI 9700pro
Sound Blaster Audigy 2
80G harddrive
PostPosted: Fri Jul 02, 2004 3:46 pm
http://www.pcpowerandcooling.com/produc ... r/dell.htm
PostPosted: Fri Jul 02, 2004 4:44 pm
pc power and cooling has them i think
PostPosted: Fri Jul 02, 2004 5:26 pm
Folding Master (Top-ranked)
Juggernaut
Unless you have added more drives or fans The power supply that came with it will be fine. Keep it clean as it is straining to do what it does now and dust on the capacitors and coils will add heat.
PostPosted: Fri Jul 02, 2004 8:15 pm
for a good PSU get an antec better for the buck
have had good luck with allied PSU cheaper can be found lots of local computer stores a good site online to order from is http://svc.com/
for direct link PSU:
http://svc.com/powersupplies.html
just make sure the PSU y in your dell is standard size some computer makers make it hard to replace them without going thru them
PostPosted: Fri Jul 02, 2004 8:53 pm
As long as you arent having stability issues, just upping the wattage of your PSU isnt going to give you better performance (by which I assume you mean FPS).
PostPosted: Fri Jul 02, 2004 11:43 pm
That answer my question. I currently do not have any problems with the system at all. I keep it clean and it keeps running.
Thanks
PostPosted: Sat Jul 03, 2004 12:38 am
Thanks
then you most likely shouldn't mess with it?
however if the need does arise this might come in handy
http://www.endpcnoise.com/cgi-bin/e/dellconverter.htm
and
http://www.google.com/search?hl=en&lr=&ie=UTF-8&safe=off&q=dell+power+supply&btnG=Search
