It is currently Sat Feb 28, 2015 8:40 pm
 Post subject: Short IDE Cables
PostPosted: Thu Jul 01, 2004 6:24 pm
Bitchin' Fast 3D Z8000*
I purchased an Antec Minuet case recently. It is really small. Does anyone know where I can purchase short IDE and floppy drive ribbon cables (rounded or flat)?
They would need to be in the 4" to 6" range. Anything else is just too long.
Hre are a couple of pics of the case (from a Tom's review here). In the second post, you're looking at the case from the left side (ie. the front of the case is on the rhs of the picture). The bracket that runs across the rhs hold both the dvd and floppy drive sitting normally, but the hd sets undearneath these two drives oriented perpendiculiarly to the case. There might be a half inch between the bottom of the bracket and the case.
edit: added pictures and a better explaination. I was in a rush the first time around.
PostPosted: Thu Jul 01, 2004 7:14 pm
i seen somewhere before where u can buy the parts to make ur own, or if ur only connecting 1 device, u can buy some longer 1s and cut 1 of the ends off. i did that with my floppy cable.
PostPosted: Thu Jul 01, 2004 7:23 pm
Contributing Writer
Contributing Writer
I'm not going to be much help in locating 4-6" cables, but what I've done in my case is fold flat cable on top of itself and hold it that way with a twisty tie. You can shorten the length significantly and everything stays tidy inside.
PostPosted: Thu Jul 01, 2004 8:44 pm
i dont know if they sell them that short unless you were to have someone custom make them for you
shortest cables i found were 10"
i agree the best bet is to fold the cables
 Post subject: Re: Short IDE Cables
PostPosted: Thu Jul 01, 2004 8:47 pm
shortest newegg has are 10", I'm to to have to 3rd (or 4th whatever) the fold flat cable idea.
PostPosted: Thu Jul 01, 2004 9:24 pm
I was considering chopping the end off the hd ribbon cable. That one needs to do a quite a bend and twist though and I was worried that I would cut it to only find out that it didn't quite reach.
PostPosted: Thu Jul 01, 2004 9:38 pm
That is what I tried initially and it didn't work so well. I ended up with two ugly, twisted, folded ribbon cables attached to the dvd and floppy. The hd is problematic because the folded cable is too thick. There are also the three rounded connectors for the switch, usb, and firewire running from the front of the case to the back. I probably would have posted that I tried this originally, if I hadn't been in such a rush.
Anyways, I went to Fry's again today shortly after posting the orginal message, and even though they didn't have any short cables there yesterday, they had a 7" twisted ATA 133 cable today! Unfortunately, it doesn't want to work with my drive. I picked up some 12" rounded cables for the floppy and dvd drive too. Those just lay across the mobo by the pci slots, which are all empty (nforce2 mobo). The 4" or 6" cables would have been ideal - this is fine though. The drive cable works better with a single fold and light twisty-tie. No one will ever see that cable anyways.
All is well now and the case is back on the little beast. Thanks for the opinions.
PostPosted: Thu Jul 01, 2004 9:39 pm
Almost forgot - I edited the orginal post and added some picks at the top.
PostPosted: Thu Jul 01, 2004 9:56 pm
Contributing Writer
Contributing Writer
Glad you got your problem solved :)
PostPosted: Thu Jul 01, 2004 10:06 pm
you could buy an IDE crimpper and make your own to custom lenghts
PostPosted: Fri Jul 02, 2004 2:18 am
I'll try and find someone doing this at a computer fair next time I am there. Making your own cables is cool, as long as you're going to do it more than once a year!
*looks over at the box of cat5 cable in the closet
PostPosted: Wed Jul 07, 2004 1:48 pm
King of All Voodoo2 Cards
http://www.pccables.com
PostPosted: Wed Jul 07, 2004 2:18 pm
http://www.frozencpu.com/cgi-bin/frozen ... earch.html
this is it
PostPosted: Wed Jul 07, 2004 6:22 pm
i know rounded cables are great for air flow but they do reduce your speed and introduce the possibility of data corruption. i wish my drive and mobo were sata for the small cables.
