It is currently Wed Jan 28, 2015 1:56 am
 Post subject: USB 2.0 issues
PostPosted: Tue Jun 29, 2004 10:50 am
I just got my new scanner which is USB 2.0 and it wont transfer in hi-speed mode, only the regular slower usb.
a box popped up about no usb host controllers installed, so I am not sure what is going on.
specs:
winXP Pro
is7 motherboard
80gig HD
40gig HD
blah blah.. if you need any more info let me know
I have checked abit website and on usbman.com but just cant get it to work. I am pretty sure the IS7 comes with 8 usb 2 ports I just cant get them to work. any advice?
PostPosted: Tue Jun 29, 2004 11:12 am
is the cable you are using USB 2.0?
PostPosted: Tue Jun 29, 2004 11:27 am
yes
PostPosted: Tue Jun 29, 2004 12:20 pm
weird... but it does scan, right?
All updated via windows updates? Check device manager to see if the USB 2.0 host controllers are installed and whatnot...
*still looking for possible problem*...
PostPosted: Tue Jun 29, 2004 12:24 pm
Forum's 3dfx Zealot
Forum's 3dfx Zealot
I had that problem with external hd and I knew my usb ports were 2.0.... What eved up being the problem was that usb 2.0 support was turned off in the bios.... So this may be his problem. as my msi board had a simple enable / disable switch on the bios right below the usb legacy option.
PostPosted: Tue Jun 29, 2004 12:33 pm
jawa has a good point. It simply might not be enabled in bios.
Make sure it's on hispeed in the USB section of your bios not fullspeed and it should be compatible, then.
PostPosted: Tue Jun 29, 2004 12:44 pm
I suggest the same as another poster, make sure its enabled in the bios. Also you can check this by going to device manager and looking around there. The highspeed usb will be called Expanded usb or something to that effect. Its not exactly that, but you will notice the difference.
PostPosted: Tue Jun 29, 2004 1:06 pm
the bios usb 2.0 setting is enabled...
but in device manager there is no usb 2.0 host controllers installed. but I have all current updates from windows update.
I dont know whats up
PostPosted: Tue Jun 29, 2004 1:09 pm
http://www.usbman.com/winxpusbguide.htm
" The final release version of the Microsoft USB 2.0 drivers are included in Windows XP Service Pack 1.
The stand alone USB 2.0 drivers have been pulled from the Microsoft Windows Update Site and Corporate Download Site.
* http://v4.windowsupdate.microsoft.com/c ... efault.asp
Complete USB 2.0 driver information is posted on the USB 2.0 page."
Try that, see if you have it. If not, download and see if it'll work.
PostPosted: Tue Jun 29, 2004 1:22 pm
I have done that, have all updates, have downloaded the update off usbman, and it still doesnt work.
yes it does scan and works properly, but its not running at usb 2.0 speed
PostPosted: Tue Jun 29, 2004 2:00 pm
Maybe your just screwed :)
PostPosted: Wed Jun 30, 2004 8:47 pm
Contributing Writer
Contributing Writer
Have you tried using a different USB port?
PostPosted: Wed Jun 30, 2004 10:01 pm
I wasn't aware scanners really truly needed usb 2.0 speeds... It's not like you have a live constant feed.
