It is currently Mon Jan 26, 2015 8:03 am
 Post subject: network usage monitor @ router level
PostPosted: Mon Jan 20, 2014 9:11 am
I'm wondering if there is something like the "Kill-a-watt" meter for network monitoring? Since most homes running wi-fi have multiple devices (laptops, phones, etc.), is there some device to plug into the router to see the consumption?
 Post subject: Re: network usage monitor @ router level
PostPosted: Mon Jan 20, 2014 9:43 am
The router may have something on its firmware. You could also install a custom firmware that has this feature like Tomato. Otherwise you could sort through https://www.google.com/search?q=wifi+ba ... annel=fflb
PostPosted: Mon Jan 20, 2014 12:10 pm
A lot of routers will log overall bandwidth usage (and a lot of other things). Check the menu.
DD-WRT
Tomato
Otherwise you are SOL for a router based solution.
