It is currently Sun Apr 26, 2015 1:31 pm
 Post subject: need help to solve pc problem
PostPosted: Thu Aug 08, 2013 10:26 pm
Hey fellas, I am using a dual core pc. Since last week it it facing some problems. It restarts automatically and it freezes some times. I want to fix this problem very quickly. So I found this http://www.techtous.com site that provides technical support. Can I trust those guys. I don't want to fry my pc buy doing unnecessary changes. If any body has worked with them or If you know a better solution, please reply.
Than you.
 Post subject: Re: need help to solve pc problem
PostPosted: Fri Aug 09, 2013 10:24 am
If it restarts automatically, it's probably a BSOD. To turn the automatic restart off so this can be confirmed:
  • Open up system properties by either:
    • Going to Control Panel -> System
    • Right clicking on My computer then selecting properties
    • Press the Windows Key + Pause/Break.
  • In the left pane, select "Advanced System Settings"
  • In the new pop-up, there are three boxes, in the bottom one labeled "Startup and Recovery", click on the "Settings..." button
  • In the "System Failure" field, uncheck the "Automatically restart" box
If it does a BSOD, there's usually a hex code that shows and a description. If you can tell us what both of those are, this could narrow down what the problem is.
PostPosted: Sat Nov 02, 2013 1:33 am
LatiosXT has given a nice suggestion. Hope it helps you to fix the problem of your system.
