It is currently Sat Jan 31, 2015 3:13 pm
 Post subject: 965 @ 4ghz possible on air?
PostPosted: Thu Jul 04, 2013 10:01 pm
I have a 965 BE with the fortunate C3 stepping.
Right now I am running it on a stable on 3.8 using a hyper 212 plus. The idle temp is 42C. I have attempted 4.0 but it BSOD and it runs too hot.
I was wondering under my current set up is 4.0 possible? My bios settings are below.
I was also thinking of getting a corsair h50/h60 (the bigger ones wont fit in my case) But I'm wondering if it is even worth it.
 Post subject: Re: 965 @ 4ghz possible on air?
PostPosted: Sat Jul 20, 2013 4:35 am
It sure looks like it is possible. I found a post on another forum written by "Covert_Death" attesting to his settings and performance.
http://www.techpowerup.com/forums/showt ... p?t=158262
Click on page 2 at the bottom of the page and look for his name.
Good luck and let us know how it worked out for you.
