It is currently Sat Mar 28, 2015 5:21 pm
 Post subject: GTX 670 3-Way SLI Upgrade Complete!
PostPosted: Sat Apr 13, 2013 4:05 pm
Upgrade complete!
I am now running three GTX 670s in 3-Way SLI cooled by three XSPC Razor GTX670 water blocks. I had to do some heavy modding in order to get them to fit, though! The stupid double-stacked DVI slot was getting in the way of the block, so, I had to Dremel it off:
At first, I was going to scrap the project and get new GPUs, I even browsed to see if Titans were in stock. Then, I decided to take my anger out on the blocks via the Dremel, haha! If the blocks wouldn't fit, I would MAKE them fit! The result:
I wrapped the 670s in an anti-static bag to protect them from sparks and debris flying all over the place:
Not pretty. Not pretty at all, yet, it worked. Blocks fitted:
Dead Space 3 Gameplay (Max Settings) - Nvidia Surround - GTX 670 3-Way SLI:
Finally got around to making a video of this game! The Dead Space series is one of my favorites, and this game definitely adds to the overall series. It's also a joy to play, as it runs smoothly and has quite the atmosphere for Nvidia Surround. This is also the first gameplay video from the GTX 480 SLI to GTX 670 3-Way SLI upgrade. Woot. :D
 Post subject: Re: GTX 670 3-Way SLI Upgrade Complete!
PostPosted: Sun Apr 14, 2013 5:36 am
Million Club - 20 Plus
Ya think ya cudda shrunk those pics a bit? :?
You may have been able to fit them on your tri-screen display but I can't on my single 27".
PostPosted: Tue Apr 16, 2013 8:27 am
Ack, all I see are caps. And I'm looking through a 17in monitor.
